  • Replies 285
well i pick up my GTR cams today and will install them on my day off this monday, will book some dyno time hopefully on wed and then post the results for everyone!
Sydney kid: would you recomend spending a few more $$ and going some adj cam gears? is it worth it or should i just throw the std cam gears onto the GTR camshafts??
Well bbenny, since you have to remove the std ones anyway, it is time efficient. You will get a better result, more in average power than max.
Bottom line is, it's your money.
Awesome, will be great to see the results
Mine arne't to far away hopefully, I am doing exhaust manifold, injectors and new ecu at the same time, so I have a bit more saving to do! :D
Sydneykid - quick question,
I want to reposition my throttle body at the front of my plenum, what are your thoughts on this? I am not doing it to see any power gain, just to get rid of some inlet piping and make it easier to adjust cams gears etc
Chris
Hi Chris, I don't like it, wouldn't do it to my car, not worth the effort. Do a search, I have written pages on why.
Cheers Sydneykid,
I searched long and hard, and have read pretty well everything I can
So is it worth using a 120degree bend, or jusy keeping it all stock?
Sorry all about the change of topic, but its all relevent to our mods and something I was considering
Regards, Chris
Cheers Sydneykid,
Regards, Chris
HiChris, the 120 degree bend design saves over 1 metre in pipe, which is 3 litres less air. So definitely worth doing in my opinion.
Well i picked up my GTR cams and they are in unbeleivable condition (thanks T88 on board) they have only done 30,000kms and look fantastic.
Re: adj cam gears
Yeah its defenantly a convenient time to change, but also adds another $399 to this mod.
if its only going to add maybe 5rwkw i wont bother but if it makes substantial gaines i will do it while its all apart. comsidering i just clicked over 100K kms the other day i will be fitting a new belt, and am now considering adj cam gears.
do you think it would be worth while sydney kid or just put that $399 towards suspension tweaks for the quarter?
thanks.
I have a 120 degree bend setup, and took a bit of work to get clear the oil filler cap, PCV valve and hoses and still be a nice and tight fit, but can be done. I would definitely recommend spending a Saturday cutting and trial fitting to get a good result, then throwing a case of beer at somons to weld up for you, nice tight fit and as others have stated cuts down a few litres of internal volume...
...the race is on to see who gets dons first...is anybody doing a before/ after run...im working on a guy to tune/clean up the maps with std cams, then GTR cams and cam gears to get a feel for the difference, as my before power figure is with a faulty AFM and A/F in the 9s and 10s...so the improvement from the tune alone should be pretty dramatic.
As for tough idles, try mega rich with fouled plugs, talk about lumpy idle (Go the Japs with their crazy rich A/Fs)
cool, i might look at doing the bend rather than cut and shut the plenum
Picked up my exhaust manifold today (cheers drifta32) so one more piece to the puzzle waiting to be put in place
Can't wait to get it all underway now!!
Chris
so what do all you guys think of adj cam gears? is it worth the extra expense? what are your experiences
You know you want to do it all at once, you just want us to give you an excuse. OK here goes......
Correcting/optimising the camshaft timing will improve the average power (10 maybe 15 rwkw) so that it doesn't drop off boost on gearchanges = faster and nicer car to drive. Better throttle response and, as a bonus, maybe 10 rwkw max power increase.
I have done one car, not ours, that made 18 rwkw more max power and 25 rwkw more average from 5,500 to 8,500 rpm after fitting the adj pulleys. But it took a fair retune to get it there, ignition and fuel where all over the place (perfect before cams and pulleys). It also had a big Turbonetics turbo on it, so it had the airflow capacity.
Better balance the books here, we also put and adj exhaust camshaft pulley on an R34 GTT expecting to get more out of the cams (not GTR). Best position was zero, so we took it off and sold it. A $50 (and 1 hours work) experiment well spent I'd say.
If they don't do anything, they are easy to sell.
How was that, convinced?
haha you should work in retail sydney kid, you know too well what i want to hear :)
any particular base setting you found worked well on the RB20?
i might give it a try and see how it goes, the only thing is ill be doing it all at once, so i wont know whether it was better than the std cam gear or not.
well i will let you all know how it goes hopefully by tuesday.
Hi, it's the usual RB settings, +2 on the inlet and -4 on the exhaust. Ours didn't like that much on the exhaust, we ended up around -3.
Sure you can, just do one power run with both cams at zero.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
    • Gee she looks a bit rear heavy in that first pic! Sounds like a great project with the kids, but as I guess you know R series stuff is getting hard to find and pre that is pretty much impossible these days
