  • Replies 125
Any other dyno results of any of the other cars on the day?
I scored a massive 179rwkw with mine.
Mines chipped standard ecu, apexi pod, apexi return flow front mount, cat back & gizzmo boost controller set at 10psi.
Good one man!
Nice 'sleeper' of car you got there :)
lol Russ not if it's tuned :P you can buy tune + warranty protection though for another k
Jamie post more pics brah :D
I realise that haha. where do you buy the tune + warranty? Is this something that FPV offer or something?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
