Noob question but thought I'd double check..I got my greddy profec b spec 2 controller installed and tuned to 12 low and 14 psi high I removed it and am thinking of getting it installed in my Gtr, can it be put straight in with out needing it retuned
https://www.sau.com.au/forums/topic/388820-boost-controller-question/
OP, what car did it come out of?
It all depends on actuator pressure as the boost controller is a % increase.. i.e. 50% on an RB25 actuator is not the same as 50% on an RB20 actuator
And as said above, I would reset the gain and setgain and tweak them from scratch to suit the setup in the new car.
Start from scratch. Its a pain in the arse to get right too. You need alot of road, alot of patience and alot of trial and error. Its a % over the current actuator setup and as said above, different tensions on different actuators will mean different things when you open your boost controller to 50%. Ive got mine on 0% low boost(14psi) and I think about 40 or 50% high boost for 20psi. Then you got gain, to make sure your boost is nice and consistent. You've also got your warning crap. Set this shit up wrong and you will be ON AND OFF BOOST, you can feel it and hear it loosing then building boost then hitting the limiter, losing boost and then building it up again.
You have set, which is your boost, then you have gain(set gain?) which controls boost falloff. Then you have start boost which is your desired boost -1psi, your warning which is your boost limit, +1psi of target boost(maybe even 2 - 3psi) then you have warning which is how much boost you would like to drop usually about 5 - 10% lower than your set. I had my boost controller, profec b spec 2, setup by CRD and they suggested the warning should be set to 0% all the time. It was perfect on my car. Anything more gave me the symptom I described above(on off)
Best to do it on a dyno where you can graph boost vs rpm so you can safely play with it without crashing your car into a tree or popping your motor because you weren't paying attention to both at once.
Also means you can get the boost curve nice and flat.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
