Guess what time it is - that's right DECA TIME!!!
It's on again and I have booked us the hotel in Shepp for the upcoming DECA.
When: Fri 24 & Sat 25 February
Where: Tirana Motor Inn
Address: 33 -37 Wyndham St, Shepparton
Cost: $50 per person per night (if sharing)
$85 per night to have a single person in a room by themselves
If you would like a room, please let me know as soon as possible, they will want to release to the public whatever rooms we are not using in a few weeks.
I need to know:
* nights staying
* how many people
* what bed configurations you need (ie twin, double etc)
If you are coming by yourself, that's fine, just let me know and I will team you up with somebody else to share a room with.
Let me know here, by email, by PM or by phone.
The sooner you tell me, the easier you make it for me.
*** NOTE - if the hotel books out, preference will be given to those staying both nights
- if you ask for a room and don't turn up without letting me know, you get added to my black list (you ppl are starting to ruin it for everyone)
Entries coming soon!!!
https://www.sau.com.au/forums/topic/389069-deca-accommodation-24-25-feb/
  • Replies 63
Fri/Sat
Bec
Ryan
Leon
Russ/Ben F/Campbell/Bobby (family room)
Femino & Kleo + Dean (family room)
Tim & Amelia
Mark & Libby
Odium + 2 (twin room)
bluey 33 + 1 (twin)
Wayne (single)
Juliette (single) & Sunday
Keiran + Lauren, Robbie Williams & Taylor (1 dbl/2 sngls)
Chris, Dan, Jett + 4 mates (2 x 1 dbl/2 sngls)
Gary + GF (double)
Jake (single)
Paul & Kat
Fri only
Ash (single)
Lowth & Craig
Leons 4 mates
Sat only
Anna/Luke
DECA is 100% open to anyone, and everyone.
More the merrier. It's a great bunch and always a good 50-60 people up for the weekend of fun :)
I'll get onto Team FA, i think a few wanted to come up for a Fri.
Cheers, been up a few times but just taken photos and enjoyed the spectating. Doing 6 broken manifold studs tomorrow on the 33, then car goes to panel shop. If car is not out of panel shop by DECA can I just bring my 180 or should I PM whom ever is in charge of the event to let them know?
Make sure you do them all - if you only fix the broken 6, 3 months later another will break... Hence do them all @ once, saves doing it again for another 10 years.
When entry forms come up you can just put down whatever car, if it changes on the day/last min that's not a major issue either. Happens sometimes.
Yea doing all 12. Had this issue on old motor, fit new gasket and new studs after snapping 5 then blew motor 1,000km later.
Fit motor from wrecked car(knowing I should of done the gasket and studs) and it has bitten me in the arse 3,000km later. :domokun: Hoping I havn't got an ongoing issue with it causing them to snap. Exhaust hangers are all ok (not using cat one though)
BEC can u put me + partner down for a room for Friday night. Twin cause partner will most likely not be my partner :whistling:
how do you put your name down to participate in the event?
Fri only
Jake (single) <<-LOOSER (stay Sat night, you know you will anyways)
Pretty sure its spelt LOSER... LOOSER is what he'll be if you throw him in a shared room with Campbell and the boys...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
