I know this has been probably covered a million times but I would like to know seriously how much difference in drone/note am I looking at if I'm changing from my Trust Ti-R to 1 of the 2. I know they're probably still illegal but if they're 91dB, its probably good enough.
What I found from reading.
Hi-Power Slient
- Quieter than Regu 06&r
- Cheaper
- No sure does the catback come with a bung
Regu 06&r
- Quiet
- Nice RB note (1 of my mate's got a Kakimoto on his R32gtr but not Regu)
- Slightly more exp
- Nice rainbow tint but not so sure about the rounded edge of the tip
- Comes with bung and greatly reduce flow
Now my question is, is the diffference significant for the Regu to run with the bung in it in terms of flow and sound? Considering my car is "stock" running only 250awkw?
BTW, if anyone is looking for a mint condition (1 or 2 scratch at the bottom) Trust Ti-R for a R33 GTR let me know. I love the look and sound of it but cruising with it is becoming annoying. Thank you.
https://www.sau.com.au/forums/topic/389172-hks-vs-kakimoto/
Ive got a mate with a Kakimoto twin muffler titanium system on his R34 gtr and it does sound good and is definatly a lot more quiet than my Ti-R system. Like you said, its probably not legal, but its close. And miles quieter than the Ti-R system.
Look at the Nismo systems if you are after something that could pass for legal.
https://www.sau.com.au/forums/topic/389172-hks-vs-kakimoto/#findComment-6201247
Cant really find anything Nismo. The only other Nismo I've seen on a Skyline (not a gtr) looks like crap. The tip is thicken and looks weird to me.
https://www.sau.com.au/forums/topic/389172-hks-vs-kakimoto/#findComment-6202664
Hks silent hi power in a rb25 r33 3" turbo back and high flow cat @ 1m and 45 degrees which is the rta check
i noted 91db at idle and 102.9 @ 4500rpm :( not silent like it is suppose to be
A mates apexi n1 full turbo back on a s15 and it was 91db @ 4500rpm and about 67-70 db @ idle.
https://www.sau.com.au/forums/topic/389172-hks-vs-kakimoto/#findComment-6202751
102.9dB!? You must be shitting me. I think mines like 95dB at 4500rpm...
Is there not the Hi-power and Hi-power silent?
Yes there is. Hi-Power and Hi-Power Slient.
https://www.sau.com.au/forums/topic/389172-hks-vs-kakimoto/#findComment-6202879
Kakimoto is perfect. Got the Regu on my car and you can barely hear it on idle. Driving around inside the cabin you can still talk to everyone without yelling, but when you open the taps it screams
I'm actually leaning towards that. Did you remove the bung by any chance or did the r32 gtr model dont come with 1?
https://www.sau.com.au/forums/topic/389172-hks-vs-kakimoto/#findComment-6206743
The regu 06 is redicoulosly quiet probably one of the quietest jap exhuasts you can get sounds like ass definately quieter than the hks. Also yes it has a welded in silencer in the cannon which reduces it down to 2 inch which I was one of the ones who discovered it and removed it but not only that the resonator they use has 2.25 inch inlet and outlet so its drops from 90mm diameter to 2.25inch.
In regards to flow for 250kw you wont find much difference when I did back to back from a straight exhuast and the kakimato with all the restrictors I lost about 8-10kw and that was running 260kw with the straight and about 250 with the kaki but yeah its basically stock sound so for a street car concerned about sound not a bad option if thats what your looking for but just know youve got a 2inch restrictors and 2.25 inch resi so as you increase power you will face restrictions. Imo no way is it worth paying 1300 for a system with restrictors making it quiet you might aswell get one made for a 1/4 of the price with restrictors.
https://www.sau.com.au/forums/topic/389172-hks-vs-kakimoto/#findComment-6212289
That's a shame, I was thinking of getting one to be stealthy
Does the HKS one have these reducers and silencers?
Dont know about hks as havent physically looked at them, but if there redicoulosly quiet then chances are yes they probably do pretty much I would say all the ones that pass the jap jasma approval would have one since there all pretty quiet. I dont know about which hks guys are saying is really quiest the ones ive heard were mid noise range.
https://www.sau.com.au/forums/topic/389172-hks-vs-kakimoto/#findComment-6212332
My friend's got a HKS JASMA system on his r34 and I have some unknown thingo with a JASMA plate on my r33 and his is deathly quiet compared to mine, no idea why.
They don't all seem to be the same, isn't the JASMA approval just an upper limit agreement for db's @ low revs?
https://www.sau.com.au/forums/topic/389172-hks-vs-kakimoto/#findComment-6212352
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
