Picked up this wreck few days ago.... it's a 1995 non V-spec R33 Gtr. Front end is smashed so front bar, lights, intercooler etc are not available. It's also had a hit on the passenger side. The engine is good so if it doesn't sell i'll keep it as a spare for my race car.
Parts can be picked up from Valley Heights Sydney or I can ship almost anything at cost.
Check in at the last page of the thread regularly as I'll keep updating what's left, I'll post pics up over the next few days.
Rb26dett engine $3,900
Runs well with good even compression. Complete engine including wiring loom, ECU, turbos, intake and exhaust, injectors, coil packs etc.
R33 Gtr gearbox $800
Non V spec diff $400
Driveshafts $150 each
Hubs $400
Front and rear cradles $150 each
Lower control arms, front $120
Fuel tank $100
Stock R33 Gtr exhaust $250
Stock R33 Gtr suspension $300
Attessa pumps $150
ABS unit $200
Stock air box $200
Has one chipped clip
Intercooler piping $200
Stock BOVs $140
Brake master and booster $100
Pair of R33 Gtr rims $550 (the other two are badly damaged and will go to the scrap yard unless someone wants to make an offer. Been quoted at least $175 per rim to repair).
Brembo brakes $1,500 front and rear or $1,200 fronts and $300 rear
Includes rotors, calipers, lines and pads with plenty of meat.
Front stock strut brace $100
Rear stock strut brace $60
Boot lid with wing $400
Rear bar $250
Tail lights $130 pair
Front bar lights $50 pair
Drivers side front guard $100
Includes Gt badge, good condition apart from a small amount of damage near indicator (see pic)
Inner guard liners with factory air guides $150
-A couple of cracks which do not affect the fit to the car at all.
Front guard GT badge $10
Drivers side door $150
Good condition, does not include interior trims
Drivers Door trim $100 (no window switch)
Passenger side door trim fabric (handy if you want to replace your damaged fabric) $20
Window switch $50 drivers side, $40 passenger side
A pillar trims $50 each
Full set of R33 Gtr floor mats $230
Excellent condition, no holes or cigarette burns. Just need a quick clean.
Centre console $60
Includes Gtr badge. One of the mounting screws is broken however this cannot be seen when the lining is placed inside.
Console stereo surround $30
Gauge cluster with 64,000km $230
Climate control unit $40
Triple gauge cluster $60
Stock stereo $40
Stock steering wheel $150
Air bag is deployed but otherwise good condition (just swap in your good airbag)
Dash pad $100
Rear vision mirror $20
Sun visors $10 each
Rear seats $330
Seat belts $40 each
B/C pillar trims $50 each
Rear trims $70 driver's side (perfect condition) $40 passenger side (has some minor damage)
Complete boot interior $150
Space saver $70
Rear window $200 (Pick up only, you remove or pay for the window dude to remove it)
Set of wipers $50
Wiper motors $50
Everything is for sale, if you need something just ask. I'm also wrecking an R33 gtst so it would help to specify in Pms whether its for Gtr or Gtst!
  • Replies 143
Posted Images
Are the rocker covers, timing belt cover & coil pack cover available separate to the engine? if so please PM me a price?
Edited by 18RZZ
How much for the front seats?
passenger seat is bent good for fabric and parts $150
driver seat jenna has already flogged and stuck in her gtr
30 bux delivered
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
