Import Monster Sauvic Deca Motorkhana - 2012 Round 1
  • Replies 378
Someone did video my 4WD hellis last year
Wish i knew who it was :(
Going by where I was standing and he (camera man) was standing I think it was 'Htial' that got the footage.
And more inspiration
And don't forget hands in cars :nyaanyaa:
So js auto importers shafted me with a cheap Chinese shit turbo when I paid a fortune for it... Even with the new ecu and shit it lags rediculously... So deca is gonna be pretty average for me :( need buy ANOTHER new turbo :(
So someone shafted me with a cheap Chinese shit turbo when I paid a fortune for it... Even with the new ecu and shit it lags rediculously... So deca is gonna be pretty average for me :( need buy ANOTHER new turbo :(
so go back to the stock one, I'm getting a nice 200 ultra responsive off mine.
btw best not flame workshops on here it's against the forum rules and you get slapped pretty hard for it
stock, only have 180K km on them have been cleaned once but that was since the tune.
stock cams
stock AFM
Walbro pump
boost restrictor taken out
kn pod filter
gktech turbo back
and a chasers nistune
i blew the stock turbo and now its highmount so i cant run a stock one now... so im going to have to fork out to buy a good garret one...
Edited by ccruzn
but seriously whoever told you a t3/t4 or a sr20 was pulling yoru leg, they better for something closer to 3L
check this out for an idea on how diff turbos respond to your sr
http://nissansilvia.com/forums/index.php?showtopic=494880
yeh js auto importers screwed me over :( iv now found a good workshop and gonna go through them.. they did my computer and tune and stuff and done a great job! they only used garret and hks n stuff so will go through them for the new turbo...
ill have a look thanks!
    • I did basically the same procedure on a ZF6HP but the reason to pull the valve body is to replace the seals between the valve body and the transmission which are notorious for leaking pressure with age causing poor shifting and burning out the clutches. If you just wanted to exchange all the fluid you should be able to undo one of the transmission cooler return lines to drain into a bucket while using the pressure filler to keep it topped off.
    • The title should have posted "EFR7670 exhaust housing selection RB26" I can seem to edit thr title on my Android.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
