Import Monster Sauvic Deca Motorkhana - 2012 Round 1
  • Replies 378
Someone did video my 4WD hellis last year
Wish i knew who it was :(
Going by where I was standing and he (camera man) was standing I think it was 'Htial' that got the footage.
And more inspiration
And don't forget hands in cars :nyaanyaa:
So js auto importers shafted me with a cheap Chinese shit turbo when I paid a fortune for it... Even with the new ecu and shit it lags rediculously... So deca is gonna be pretty average for me :( need buy ANOTHER new turbo :(
So someone shafted me with a cheap Chinese shit turbo when I paid a fortune for it... Even with the new ecu and shit it lags rediculously... So deca is gonna be pretty average for me :( need buy ANOTHER new turbo :(
so go back to the stock one, I'm getting a nice 200 ultra responsive off mine.
btw best not flame workshops on here it's against the forum rules and you get slapped pretty hard for it
stock, only have 180K km on them have been cleaned once but that was since the tune.
stock cams
stock AFM
Walbro pump
boost restrictor taken out
kn pod filter
gktech turbo back
and a chasers nistune
i blew the stock turbo and now its highmount so i cant run a stock one now... so im going to have to fork out to buy a good garret one...
Edited by ccruzn
but seriously whoever told you a t3/t4 or a sr20 was pulling yoru leg, they better for something closer to 3L
check this out for an idea on how diff turbos respond to your sr
http://nissansilvia.com/forums/index.php?showtopic=494880
yeh js auto importers screwed me over :( iv now found a good workshop and gonna go through them.. they did my computer and tune and stuff and done a great job! they only used garret and hks n stuff so will go through them for the new turbo...
ill have a look thanks!
    • Hell, I'm sufficiently wary of the ZSS suspension arms, let alone something like a hub.
    • Got it back home and got started pulling the hub off and diagnose the issue. Axle was stuck after removing the 36mm nut so i used a 3 jaw puller to try and push it out and... eH5FXvJ8.mp4   spend the next few hours trying to remove the axle from the remaining hub as it was very much jammed in there when the spindle sheared off. resulting damage as below R53AIy6 - Imgur.mp4   Looks like the was already a stress fracturing in the spindle as can be seen with the darker cracked section My working theory is maybe when the pinion gear exploded last year the shock put through the hub was the initial crack. Then a few events later it finally let go. Just lucky it happened where it did and not 190km/h on the next sweeper or into the hairpin The bearing/hub assembly went in in 2019 and were non-genuine "ZSS" assemblies and no nails were harmed in the process. #BreakHubsNotNails
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
