SHepp has a really good st vinnes, 4-5 reject/2$ shops and um, yeah will get back to you on that!!
(translation just help all day ;)
You forgot SPC/Ardmona - bahahahahaha!
I'll do all day Bec, so put me on skidpan in arvo too :)
Just bumping up, hopefully we can fill all the spots before the day :banana:
hopefully it wont be like previous times where the day almost dosent go ahead cause people cbf or are a bit selfish
being a volunteer dosent mean you cant ride along in your mates/other peoples cars :thumbsup:
THE FIRST FOR 2012
Sat 25 February
And once again we ask for your assistance
For this event to SMOOTH on TIME and SAFELY we need a small group of volunteers (OFFICIALS) to help
out in 3 sections in the morning and 1 in the afternoon.
All Officials on the day will be supplied lunch and drinks.
An Officials breifing will be held before the drivers breifing. So all Officials will need to be at
the Shepparton DECA complex before 8am on Saturday.
Be aware NO DRIVERS BREIFING OR COMPERTITION will take place until all Officials positions have beed filled.
So if this sounds like you or 1 or more of your friends or family post up in here and i add you to my list.
Cheers
MORNING
SKIPPAN
Starter.. Wayne
Finisher.. Martin
Timer..
Spotter.. Josh _TypeX
MINI WANG
Starter.. Campbell
Finisher.. Keiran
Timer.. Lauren
LONG WANG
Starter.. Anna
Finisher.. Juliette
Timer..
Spotter.. Sam
Spotter.. Sachi
AFTERNOON
SKIDPAN
Starter.. Wayne
Finisher.. Martin
Finisher..
Timer..
Timer.. Keiran
Timer.. Anna
Just a reminder guys we are still looking for a few more people to help us out on the day.
So if your heading up for a look put your hand up .
We will not start until we have enough Officials.
WayneO
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
    • Have you done 10x restarts since it came on?
