been driving thru a fair bit of water with the floods up here (tweed area), car cut out on me (c34 stagea)and now will turn over and try to start but wont fire up,checked fuel pump all ok any ideas apprecciated.
https://www.sau.com.au/forums/topic/389560-no-go/
Possible condensation under coil cover
https://www.sau.com.au/forums/topic/389560-no-go/#findComment-6206524
Park the Stagboat up if you haven't already, give it a couple of days to dry out while you transfer the golf clubs into the Pudge e ot. Try again on Monday? :thumbsup: Best bet.
Cheers, GW
https://www.sau.com.au/forums/topic/389560-no-go/#findComment-6207077
just hope that it is wet electrics that need to dry out and not something worse. driving through flood water can end badly. there is always the chance that you will either suck water into the engine (not a good thing), or the car will stall and not start again, meaning you have to leave it there and go get help. if the water is rising fast the car may be underwater by the time you get back.
https://www.sau.com.au/forums/topic/389560-no-go/#findComment-6207444
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
    • Wrong side of sydney for me coming from Goulburn, but you should head along, all ages of Skylines will be very welcome
