hey guys just wondering about the gt3076
what kind of power figures can the gt3076 with the internal wastegate .76 rear housing make on a rb25det with supporting mods
from my understanding and results ive seen that they are not the best choice of rear housing for the turbo to suit the rb25 engine
can anyone help
https://www.sau.com.au/forums/topic/389707-gt3076r-with-76-rear/
  • Replies 62
ive never heard of that one, far as i know its either .63 or .82 , i would not even try non genuine garrett housing, you looking for trouble there, if you want the best results then dont try and take short cuts, stay with a .82
yeah i know i had a guy offer me a gt3076
its the .76 internal gate rear housing which is a direct bolt on for our rb20/rb25 dump pipe pleaces like GCG and tweakit sell it
im a bit worried as its not a genuine garrett housing as i only want a .82 and im happy to make my own dump pipe to suit
but the guy claims he made 284rwkw on a rb25 on bp98 with only 18psi
if it were me , i wouldnt take any chances, by the the time you've paid for it to be dyno tuning and it turns out the housing is crap ,you'll wish you'd just gone genuine,
the .82 is proven over time so atleast theres confidence in it.. up to you though how much you want to give things a go and re dyno etc.
i went .82 with external cause i wanted to eliminate any issues..
hmmm... is he a known trader/common on the forum?
just interesting that he made exactly the same power as me on exactly the same boost on 98....
just make sure he is legit.....
those avo type housings are tried and tested............ and turned out to be shit
you can find plenty of info about them on this forum if you look hard enough. its a lucky dip how it will go, some are usable some are just rubbish and you definitely wont get your 300kw that you want.
if you want a simple 300kw follow Stao's mods to the tee and bolt a G3 on it. you should get over 300.
Why not a SS2, more responsive than a G3 and is just in the 300rwkw category?
Why not a SS2, more responsive than a G3 and is 'just' in the 300rwkw category?
Are you sure its .76?? Most likely to be a .73AR internal wastegate Skyline housing from AVO turboworld
http://www.avoturbo.com/pdf/gts_exhaust_housing.pdf
Rated to between 280-300rwkw at around 20-22psi on 98Ron fuel.
Nothing wrong with this exhaust housing whatsoever, been running it for a number of years. Spools up nicely, puts down the power well.
"very shit" my arse
Didn't mean to offend was referring to it making 300rwke on sensible boost, tweakit as I said .76
http://www.tweakit.net/shop/product_info.php?cPath=326_367_378&products_id=6637
Not to sure if It will make the power I'm after they do claim it will make 330rwkw but I'm sure that's prob 25/30psi lol
I haven't really seen any results on the ss2 in the 300rwkw on 18psi
And what's the transition of boost like ie between gears and driving in traffic,
Then it comes down to price
As a Garrett gt3076 will be cheaper what will make close to 300 easier with less lag and more reliability
if i was to get a gt3076 im happy to go external wastegate thats not a problem
but im atill trying to convince myself if a hypergear will be as responsive as a 3076 and make 300 well 290rwkw IW on 18psi but looking at dynos it seems they spike a bit
can anyone comment what would be the better option
its goin to cost about the same for the hypergear as its goin to for the 3076
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
