Sorry I cant make it either Richo.
Got a new Brake Master Cylinder put on today. A bigger, better, larger unit to suit the Brembo's. BM57. (Bigger than 1")
Instead of the BM50 for the Sumitomos (1")
Now I have braking issues - Again :(
Booked in again Wednesday to get it looked at.
Sin
Stocker should work fine with the Brembos. But then so should BM57, what's the issue?
The stocker became spongy when I had the New rotors and Brembo calipers put on. Pedders put the rear calipers on the wrong side therefore the bleed valve was opposite to where it shouldve been and air got stuck. :(. Took it back twice and they didnt work it out. Took it around the corner to ACT brakes and within 1 minute they told me the problem. So they put them on the right sides and up the right way bled, and all good.
Because I put the Bremo's on I bought the BM57 to suit. Today ACT Brakes put it on and I am back to spongy.
When the ehgine isnt on the brake peddel is hard. Turn the engine on and they go instantly spongy.So doesnt appear to be air trapped in system.
So anyway - back to ACT brakes on Wednesday. If they cant resolve within the day I'll get them to put the BM50 on. As it turned out to be very good.
I thought I'd get better stopping with the match of Brembo calipers and the BM57 like the Vspec I and II.
The bigger BM57 will give you slightly shorter pedal travel and a harder pedal so while the stocker will decrease harness and increase travel it shouldn't be excessive or spongy. The movement when you turn the engine on is it 'sponginess' or 'travel' because the booster is getting vacuum?
Edited by Scooby
The booster appears to get vacuum as it should but the sponginess is more than should be.
There should be a point where the pressure increases and then goes fairly hard as the brakes are applied
I dont get to the hard bit and the first half is soft like there is no pressure.
Any ideas ??
The other thing that annoys me is that every brake shop discounts bleeding the ABS without reason - Why is that?
It connects directly to the BMC, it has the capacity to trap air, it's higher than the calipers and higher than anything else in the brake system (except the BMC which is pretty much at the same level), it has bleed valves on top of it !
I'm not a brake specialist BUT i am mechanicaly minded and logical.
Any ideas ??
Faulty valve or torn diaphragm?
  • 1 month later...
So how many of you keen to go for a drive this comming weekend ??
Thinking of grabbing a big breaky in Cooma (1hr away) then maybe a short stop at Jindy for photo op and then lunch at Charlottes private parts.
Maybe even cold drinks when we get back
Following weekend is Wheels @ old parly house.
I won't do it this weekend, doing Motorkhana on Sunday.
But I was close to driving out that way last weekend (Canberra long weekend) until the R32 engine died while out and about. Anyway that got me wondering if any of the roads up there had been closed from the recent rain? A majority of the fun roads were closed and we found out for good reason.
Ahh man would be keen! But I'm getting my St pats day celebrations on.. come on St pat's day on a Saturday! Its like a lunar eclipse...
But next few weekends ill be available. Ill also be getting new rims which will need a photo shoot.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
    • That could easily make a horrible noise. +1 to the benefits of: a) Disclosing all relevant information when asking questions such as these, b) Actually going out and having a look at your own car, seeing as you're the one there, and we're not!
