Just need some opinions on this,
would there be any benefit or even issues with a 4inch intake comming off a gtx3076 with 4inch anti surge compressor housing?
thinking of having a 4inch intake then reducing down to 3inch and putting filter down in the front bumper,
so second question is will the afm being X distance from turbo and having 4inch pipe behind it be an issue with idle/running?
https://www.sau.com.au/forums/topic/390439-afm-position-and-intake-size/
4 inch intake and map sensor, run the AFM in the hot pipe or mount the AFM in a 4 inch pipe. Any other way and you may as well run 80mm to the turbo imo.
so run the afm just after the turbo outlet and before the intercooler and then use 4inch from turbo to filter plus use a 4inch filter pod , yes?
ok cool , ill make sure its 40mm atleast,
my thinking with the 4inch pipe and 4inch filter was that at say 20psi or later on at 24psi , it might give greater response and more power, similar to having a 3inch or 4inch dump pipe when the turbine is only 60mm it may squeeze a little more out of the setup.
GTX3076R flows a fair chunk more than its little brother. Not only that, but those fancy compressor wheels dont come alive until after 25psi.
Saw a video of one push ~500rwhp. I think it was a red or pink S14?
I thought afm's didnt like being on the discharge side of things?
Ty.
afm before the turbo is fine, just use a 4"-3" reducer somewhere between the turbo and afm. aslong as theres a bend and atleast ~400+mm between the turbo and afm it'll be fine.
+1
Will be fine going from 3"-->4"
It's how virtually all other set-ups do it
How much power you going for
Id be happy with 300-320rwkw with a huge torquey midrange, just ordered tomei cams, and later might go E85 with some forged pistons.
is a few weeks off tuning, hoping the HD exedy will hang on too, a few issues to deal with yet.
so has anyone put the air flow in the cooling line and ran 20psi without issues?
Edited by SliverS2
yes people have, but other people have completely busted them doing this too. leave it in the standard position.
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
