Hi guys,
Last night i went out for a run in the 32gtr Launched in first. then boosted up to 180,
as soon as i let off a loud ticking/pinging sound was coming out from the engine,
I turned it off at a mates and let it cool down, started back up but only made the sound when free reving above 3000 RPM
Took off to take it home and under load it wouldnt make the sound or backing off, only when in between load and off load if that makes sense (cruising), by the time i got home the ticking/knocking had worsened and was doing it at idle.
any ideas? i'h hoping its not a big end as it sound like is coming from the top? (car still drives/boosts and revs fine.
Regards Jimmi
https://www.sau.com.au/forums/topic/390568-rb26-nasty-knocking/
It could be anything. I'm going to say noisy lifters. If you had a big end spun, you would know. It would sound more like a hammer on your block. If its a light tap, knocking sound, its probably head related. I'd put some new oil in it and see what it does. If the problem gets worse, louder, constant etc it may well and truly be a big end or some other thing at the bottom.
I experienced the exact same sound about 4 weeks ago. Turns out i spun no.5 bearing. Fairly similar situation too, mine was caused by oil starvation.. Not good.
Hopefully you have better luck than i did. Take it to a mechanic, or get one to come to you..
Best of luck mate.
id say the luanch then full throttle all the way to 180 is pretty much a give away that the cause of the problem was oil starvation
What i wanna know is
-what power are u running?
-what engine mods do u have and do u run a baffle or modified sump?
-do you overfill your sump?
Hi guys,
Car is a Late 1993,
Power FC
Twin Nismo t28's
Tune
Standard Injectors,
Running 17psi At the time
Standard Sump not overfilled.
Air Temp at the time roughly 18-20 C
Roughly 355rwhp
Oh and 72,000kms,
Edited by GTRSOL
Did i say that the head flooded with oil?
how would the head flood with oil if the oil pick up isnt picking any up
If you are pulling hard G's for an exteneded period of time, which is entirly possible in a GTR that performs a hard launch then is full throttle all the way to 180kms, then you can starve the engine of oil as the oil is not near the pick up...
insane?.. i think not
I wasn't going against what you said, I just assumed you were probably implying that any useable oil would have been flooded into the head! Ive read that it doesn't take very long at all on some high rpm to fill the head up with pretty much all useable oil in the sump.
Pulling enough G's and maintaining that in a straight line to starve the engine of oil.... that is crazy shit insane! Its amazing to see these oil control issues evident in skylines. They are all very possible situations and you would think Nissan would have thought of ways to prevent this stuff from happening.
Also those KM readings, 72000km.......................................................................................................................... nah.
Is it a bad thing to overfill your sump? It takes me some good time to fill up my car and get it exactly on the right mark on the dip stick. I over filled it once and I let some oil out because I read it can do bad things but I didn't see how or why...
Edited by SargeRX8
So, if the oil is not in the sump, where is it?
How the could the head flood with oil? I would have though it was obvious that this would happen before the sump is empty.
sorry to hear mate
so is it a good idea to overfill 26's with oil??
Yes. For track work, many fill the the bottom of the top bump on the dipstick. So about a cm above the full of the hatched area.
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
