Hi all,
I've recently had my engine rebuilt using Arias forged pistons and am getting huge blow-by and a huge drop in compression pressure ( should be 120psi-140psi but I'm getting 75psi-85psi ) :cuss:
I'm told that the rings are not bedded in and I need to replace these rings and bead hone the bores to fix the problem. I'm also being told by another source that these rings are simply no good and I should get Tomei pistons and rings.
I would really like to hear from anyone who has actually used Arias forgies in their turbo nissan and what the results were like ( before I possibly go ahead and waste more money doing the rings and bore hone ).
Thanks.
https://www.sau.com.au/forums/topic/39070-arias-forgies-problems/
Sounds like bullshite. Why would one brand (and an expensive one at that) be so much better than a trusted one like Arias.
The original builder screwed the job more likely.
T.
Thanks all.
Well from what I'm told, the people who built my engine are some of the best in the game so I'm now putting the problem down to the oil that was put in (as run-in oil ) by the guys who fitted the engine, or the way I ran it in ( if that's possible ).
I guess my next questions are...... How did you run in your engine ? What oil did you use to run it in ? and How many kms for ?
Thanks.
I've just rebuilt my engine with Arias and have to that I've had no problems what so ever. Engine runs better than ever. I ran it in for 1,000 kms with running in oil (very thin) then changed to like a half/half mineral/synthetic mix for another 500 then switched to my normal oil 10W-40/50 (can't recall).
To give you an idea of how much better mine is now, I can chirp third consistently with 255's on the back!
Used run in oil in mine for 500km's, did a full flush and replaced with Mobil 1 5W-50 for 500kms, did flush again, Mobil 1 5w-50 for 2500kms, did flush, and now its got Mobil 1 5W-50 in it and it goes better than ever.
When running it in I was told to put the engine under load (going up steep hills in a high gear like 3rd/4th so the engine has to work to get up it), never kept a constant speed, never idled for too long and it all seems to have worked well.
Same advice i was given, and will stick by. Gotta give it sum stick to get those rings to expand, and bed in.
Yeah, I also never maintained one speed...ie driving down a 100km/h freeway i'd do 90, then 95, then 100, then 105 (no i wasn't speeding, it just appears that way), up to 110, back to 90, etc...
Never let it idle for too long, basically drove it without boost but did load it up in high gears but not all the time. Seems to have worked for me.
If you intend to hit the car hard for the entirety of it's life, you have to hit from day 1.
So common wisdom is that you flog it hard.
T.
could it be that the clearances set by the engine builder were a little on the large side? as in to allow massive boost etc?
Recently ran in mine using Arias ....... ran it in very similar to Amaru .... no problems what so ever .... only thing is my car sounds liek a ute when i start it up now ..... im not sure if thats normal or not
I've heard quite a few Arias fitted RB engines and they generally sound less "rattley" than say an engine rebuilt with Wiseco slugs.
I've been told that this is because they have a lower co-efficient of thermal expansion compared to other forged pistons, and therefore the clearances can be less (ie more in line with OEM pistons).
Anyone know for sure?
GAV: i dont know were you heard that from but i had wiseco's in my engine when i rebuilt it and it never rattled, nor did it rattle with the ariais in the previous engine. how ever i did get some blow by with the arias.
In regards to running in, I used motul oil and drove it slowly for the 1st 200kms then started canning it from then on. At jamboree last yr when i raced the engine was under 500kms old on the saturday.
Come 7 months/ 10 000kms later the car is still going and going strong.
i guess it just comes down to the way the engine is built
harun
yeah the engine build is very important but the way you run the engine in will determine if you have a good engine or not, doesent matter if the engine is done perfect if you do it wrong it will burn oil.
im currently getting my engine built and getting a 550hp setup together, my biggest problem is running the engine in as i have a new computer and will not be able to run the stocker as i have a 32 and fitting a rb25engine, so i need to tune and run in together, not a good thing
i used arias pistons when i rebuild my rb 26 , 87 mm , 4 thou clearance . as with all chrome rings you need a good hone . i used run in oil for 800 k then mineral oil for 4000 k then helix ultra . when running it in put it under load from the start but only for short periods like full throtle in higher gear for like 20-30 seconds then back off then on again . i have no problems with blowby whatsoever and 175 compression .
fat 32 , did they bore it out to suit the new pistons ? the clearances maybe to big or the ring gaps to big
Thanks for all the info Guys & Girls.
Here's the low-down. ProFlow at Rossmore built the engine and they're renowned for building high quality and high power engines ( mostly big HP V8's for drags ) and I have very little doubt in the quality of their workmanship ( however, after sales service leaves a little to be desired ). The bores were machined to suit 40 thou oversized Arias slugs.
The guy that installed the engine ( not ProFlow ) put Synthetic 5w40 oil in as run in oil which I didn't know about ( and don't really think is correct ). He believes that itwill make no difference at all to the run-in.
The car: From a cold start up to operating temp, the engine is as quiet as a mouse and driving the car is reasonable until you hit the loud pedal and get up on 18-20psi boost and then the oil catch can goes from empty to full in no time flat ! I ran the engine in for about 400kms before changing oil and filter but the car just seems to be going down in power every time I drive it.
From all that I've heard now ( forums, workshops, and owners ), it would appear that Arias pistons and rings are great so long as boost is kept below 18psi ( due to ring design ) and if you want to run bigger boost than that you're best to get Tomei or Jun pistons. This is only a conclusion that I've made from talking to around 40 or so people re this subject.
Since I'm essentially broke at the moment I'm thinking of doing what Chris32 ( and others )suggested and chuck some mineral based run-in oil in, turn down the boost to about 14psi max and thrash the nuts out of it to see if the ring might bed in. If this doesn't work I'll just park the car and start stripping it :D
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
