Sorry if this drags on!!
Up for sale today was my key to the very unique look i was aiming for with my beloved Matte White Supra
A set of custom Chartreuse Yellow Work Meisters S1, all wrapped up in Kuhmo KU36 semi slicks
They were originally bought in average condition, but once i decided on the look i was after, they were sent off to Import Monster to get the royal treatment done.
It took about 5 months total to get the finished product, as new outers (painted dish) were sourced and machined to bold up to the centers and the inner section of the wheels
Dimensions of the rims are as follows:
Fronts
18"x10.5", offset is unknown
KU36's have roughly 70% tread left
Rears
18"x12", offset is also unknown
KU36's have roughly 10% left (only put these on to get from a to b, but the wheels did not fit)
One of the front wheels has a small section of paint chipped off due to my careless brother shifting them about :@
Ill stress it now, if you plan on fitting these to a stock bodied supra, i highly suggest you get yourself either a slight wide body or over fenders of some sort for the rear
When i test fitted them to my supra (stock guards) the fronts seemed fine, but the rears were my problem
In my opinion these are as awesome as f**k. (pardon the french)
I also highly advise test fitting before purchase, which can be arranged with me :)
Any interstate buyers, unless you are prepared to make your car fit the wheels, there is not much i can do in terms of test fitments :P
These wheels cost me a total of 5.7k in the end (purchasing, refurbishment, paint, assembly and tyres)
They have not been used since being assembled apart from two wheels being test fitted to my supra
I am looking for $5,000 as they are
It may seem like a lot to most people, but consider this
as far as i know, you can only purchase new Meisters with a maximum of around 10.5-11"? (correct me if i am wrong! :P)
and again as far as i know, they will cost a fraction over $4,000 for a set without tyres
These are very different and again have freshly been refurbished and never used
Words nor pictures cannot even begin to explain how damn sweet they look in the sun light.. you really have to see them in the flesh!
ill let the pictures do the talking
These stickers are also included in the sale, didn't know if i wanted to put them on or not
Reason for sale, my Supra will be sold soon to make room for a Stagea, and these are way too clean to use on my z20 drifter, so they must go!
I can be contacted on 0423 985 five seven one, and am located in VIC (Caroline Springs)
any questions, ill so my best to answer! these will be advertised on few forums so it will be first in, best dressed!
Cheers
Ken
cheers chris :)
ill find out both tyre sizes when i get back home later this arvo relyt
I think you will have better luck selling the wheels if you measure the offset with a ruler even if it is approximate it will only be like 1-2mm error
there are guides on how to do it all over the internet
also what are the disk spec on the faces, big brake clearance or pretty low disk?
iirc Meisters are available up to 18"x15" size from the Work site
just did a quick google search about diy offset measurement, ill have a crack at it tonight
What would you be referring to when you say 'disc spec on the faces'? i wouldn't have a clue :P
In regards to BBC, i am not entirely sure,
when i originally purchased the Meisters in their original form, they came off an RZ supra with big brakes, considering the facing is still the same id say it should still clear supra big brakes,
But this of course is SAU, so that's pretty much useless :P
Id be more than happy to test fit to any skylines, s15's and etc with big brakes! It would be helpful to know if they would clear for you guys or not :)
Cheers
Ken
also ill remove the section about the new work wheels, as i have been mistake :P
Cheers Roman!
these are mental! make ur car fit them, they will look awsome! tried getting my wheels painted in same vibrance but orange and the shop couldnt do it :/
that was the plan! but a m35 stagea is such a better option for me :P so the supras going!
Its very very tricky with colours as vibrant as these to do it, ill be doing the same theme hopefully to my z20 and my stagea when it eventually arrives!! :P
For some reason, i am un able to edit the first post, so ill put the offsets and tyre sizes here
If a mod is reading this, could you please edit the topic for me?
anyway they are as follows
FRONTS, -27 offset
TYRES, 235/40ZR18 95W
REARS, 0 offset
TYRES, 265/35ZR18 97W
Thanks guys!
Cheers
Ken
ah whoops! yes +27, pressed the wrong button
Callan, the wheels have been re-furbished and widened, so offsets have changed
Price Drop
4,800
Price Drop
4,800
If they have been widened and all that jazz, whoevers done the work should know what the offsets are. It would help with your sale.
Just offering my Personal experience here. Those fronts look to be something like 9.5 +24, and if it clear Supra big brakes, it will clear GTR/S15/[insert datsun] big brakes, and 6 Piston Alcon/Grex calipers, as Supra brakes are actually wider than them.
This is with 19 x 9.5 +20
The rears, these were my 19 x 11 +18 SSR on my Supra...which look ssimilar to the fitment on your Meisters. Hope that helps man.
damn ive always been jealous of your gorilla :P
thank you though!
anyway, yeah it is a bit of a pain not having specific offsets, but i am doing what i can, the offsets i measured are a few posts up anyway.. shame i cant modify the first post
but anyway test fitment is something i definitely suggest to any potential buyers as previously mentioned
Cheers
Ken
