didn't remove the calipers, just the pads. Masked up the rotors an covered the rest of the surrounding areas with newspaper.
as for the letters, masking tape, very sharp scalpal, and a lot of time. after i sprayed the blue I removed the tape off the letters, then painted the NISSAN letter white by hand with a small model paint brush.
I'm pretty sure there's a full guide to this on the maintenance forum.
That white car, dark BBS style rims, GT wing and blue calipers is a masterstroke. It looks the part!
I have a silver 33, bronze TE37 rims and I want to paint the calipers.
What colour do you reckon?
blue, gold or red?
Or silver?
Here's pics:
http://www.nitroware.net/~tony/r33tints1.jpg
http://www.nitroware.net/~tony/r33tints2.jpg
T.
blue, gold or red?
Or silver?
dont reckon gold...clash with your awsome wheels. Silver would be ok but wouldnt stand out much.....I reckon blue would look good.....
but i think Maroon (same as on your GT badge) with white letters would look sweet as!!
looks nuts.... btw calipers get hot as what model paint did you use? or did you use a modelling brush to apply heat resistant paint?
Did you use a primer, did you sand or buff the caliper back first?
lol...yeah i know they got hot....just used a modelling brush, the paint is white engine block paint....up tp 550 degrees celcius i think?
didnt use primer, used metho and an old paint brush to clean the calipers VERY thoroughly, then used a bit more metho on a clean rag an wiped them down till no more dirt came off. I dont believe caliper or engine block spray pack paint requires primer, just be sure the surface is super clean. :D
i've got a light silver series 2 r33 gts-t and am thinking of doing something similar .. i went through all the colors of the rainbow and more and digitally changed the calipers on a picture of my car ... blue is seriously the only color that looks good on a silver car in my opinion
taking the calipers off isnt hard...just a few bolts and clips....even if yiu wanted to dissconnect them an paint them on the shelf isnt really difficult, just have to bleed the brakes and add a bit more brake fluid.
I just didnt see the point, its easy enough to do them on the car, and they come up quite well. So long as you put more time into your preperation than actual painting, should all be good.
jus look at mine :D
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
