Hi everyone,
I want to upgrade the exhaust on my 97 model GTR, currently it only has a 3 inch pipe from CAT back into nismo rear muffler.
I find it drones a bit on the freeway which I hate. I want something that doesn't drone but once you hit boost the amazing sound of the RB26DETT comes to life.
Any recommendations from Turbo back?
Thanks
Engine is completely stock. I just don't want it to drone on the freeway, but still have some loudness about it.
budget: Any.
was thinking of upgrading the dump pipes, high flow cat then rest of the exhaust.
I've heard some GTRs and they sound awesome.
My friend that has a R32 GTR (everything stock on engine bar FMIC) has a Fujitsubo 3 inch and sounds awesome. I think dumps are Tomei. The rest is Fujitsubo.
Hi-flow cat, too. But in saying that.. I think HKS Superdragger sounds tough.
i just replaced my dump and cat with 3.5inch hiflow and now the exhaust sounds alot better, fujitsubo 3 1/2inch catback, same muffler but now its not that quiet anymore lol
mine might be up for sale soon
custom made 3.5" stainless steel from cat back with rear cannon muffler (3.5" id).
have a cat somewhere for it too. think it's a 3" cat that is flared to 3.5" to fit the rest of the system.
i think it sounds great but my front/pipes are not standard...nor is the engine.
What is this coming off of? I love the idea of a nice, light titanium system.. But the sound is a little... "tinny" for me. At least, the few that i have heard.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
