hey guy first post so gimme a break lol, I just got a 32 gtst w rb20,ok first thing is I plumbed the catch can properly ie t'd the pipes on the rocker covers and ran that to the can and the other pipe to the pcv, now its sucking air from where the dip stick is, to the point its still sucking when the engines turned off I know vaccume is good but geese, also its having trouble idleing, it revs erraticly sometimes and pops and farts, it has an exhaust leak at the dump would that do it? Any help will be appreicated, cheers.
https://www.sau.com.au/forums/topic/391469-a-few-32-qs/
your setup looks right, is ur dip stick poping out and if so it could be blow by (if u dont know what blow by is it is when ur rings r on ther way out and the boost pressure makes it way pass the rings and presurise the sump) if u think its that turn ur boost down ur boost might be to high for the age of the motor. and if u dont think its that f**ks me what it is ;p
https://www.sau.com.au/forums/topic/391469-a-few-32-qs/#findComment-6231439
Don't think so. The PCV should connect directly to the RH (driver's) rocker cover (as Nissan installed it). The other side of the can then connects to the intake pipe, just in front of the turbo.
https://www.sau.com.au/forums/topic/391469-a-few-32-qs/#findComment-6231515
Oh ok, so the pcv has nothing to do with the catch can? Also the idle things starting to annoy me :s the tps isnt working properly, it will read 10.8v or 13.4 nothing in between. Oh yea and it had engine oil inside it.
You are sucking the catch can gasses into the plenum right? Put the PCV back and plumb the catch can into the turbo intake like it was before you stuffed around with it.
https://www.sau.com.au/forums/topic/391469-a-few-32-qs/#findComment-6231858
Yea its plumbed into the pcv, the can had a breather on it thats why I stuffed around with it lol. I just read an article about pcv valves on rb's and the fact there only open at idle/vacumm oh well lear from ya mistakes ay. Anyone with ideas on the idle situation?
https://www.sau.com.au/forums/topic/391469-a-few-32-qs/#findComment-6231890
Have you checked for all your vac lines for leaks?My 32 almost stalls every time I pull up, and another guy I know his 32 did the same until he got a nistune.Maybe take the throttle body off & give it a clean out. Just an idea.
https://www.sau.com.au/forums/topic/391469-a-few-32-qs/#findComment-6232387
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
