buster,
We all agree that your car only does 11's when you want it to. You decide when you'd like to go quick or if you'd like to putt around.
If you have the power under your foot you can choose to use it or not if you have a large turbo or an equivalent nitrous kit. It doesn't really matter. So in reality your car is only an 11 second car 'some of the time' and not all of the time regardless.
You will find the nitrous equiped car is much the same concept, just a different application.
Once you actually have owned a nitrous equiped car you will understand what I mean. So often is the case that people who don't struggle to grasp just how easy it is to activate and how long a tank actually does last driving around.
I think if you are in for circuit stuff then you won't get the same enjoyment out of a nitrous kit as a nice big turbo setup. But it still doesn't mean you can't have both. And when it comes to the straight line nitrous is alot cheaper and perhaps even a tad more fun.
buster,
didn't have a chance to do any timing device stuff. Was a week off going to the motorplex with the better part of 150hp shot when the roo's made the change of plan (no nitrous involved there).
The old bus had the go to do a high 12 without gas. It ran a 13.3 with a major tuning issue without gas and a 2.3 60ft (thanks to uneven inflation on the rear tyres) so I was guessing a mid to low 12 would be very easy. Pushing the envelope a little probably 11's but, that would have made it more of an iceskating run. I think I had an offer of some 540's for the day too so had it all come off maybe a low 11? You never know. The batton is passed to adrian now so I reckon he can get pretty close to a 10 with the same hit I used, well I hope he does anyway.
We all agree that your car only does 11's when you want it to. You decide when you'd like to go quick or if you'd like to putt around. If you have the power under your foot you can choose to use it or not if you have a large turbo or an equivalent nitrous kit. It doesn't really matter. So in reality your car is only an 11 second car 'some of the time' and not all of the time regardless.
True rev though I thought using nitrous was illegal to use on the street and would become very very expensive if you tried to use it all the time, my 11 sec car is an 11 sec car when ever and where ever I want it to be
Yes I do agree it is at the strip or track but just having the power at the strip or track may not suit every one, like myself who enjoys the power all the time
Once you've actually owned a GTST that runs 11's at 128mph without gas you might understand where i'm coming from as theres nothing like knowing you've got the power when ever and where ever you may need it
Buster,
Doing anything like an 11 second pass on the street is illegal too. I'm sure you aren't saying that you drive around the suburbs with full throttle every second of the way with a 2wd, you don't have a GTR so even if you wanted too it wouldn't happen. If you are responsible I guess the 11 second pass is only legal on the strip (or maybe darwin :P ).
I understand where you are coming from I've been there with other cars. And I'm probably going there again with the gtr.
As for knowing you've got the power " when ever or where ever you need it " , adrian will tell you (as I'm sure other people who have owned nitrous equiped cars would) this is his understanding about his car too. If thats your bottom line there isn't a fig of difference, appart from an occasional tank refill.
  • 1 month later...
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
