Hi Fellas,
There is a R33 GTS-T which im very close to buying, i just want to get a report from REVs about previous write off status and if there is any encumbrance. I have put the vin number on the REVs website and the rego but it says that there is no match in there database? could they not support imports?
Any other recommendations for things to look for/ test to conduct ?
Cheers
https://www.sau.com.au/forums/topic/391673-pre-purchase-question/
Take someone with you who knows Skylines and get them to go over it.
It's amazing what you figure out about these things after owning one.
Whereabouts is it located?
Im using the vin number 6U9000ECR33107095
That's the number on the vic roads website when i put the rego in ... pinch.gif
Here the the carsales link to the car http://www.carsales....282&distance=25
Edited by Radion
93 model made in september. AT f4 is auto confirmed by putting my vin in it said MT F5 guessing 5 speed manual.
Hope this helped mate.
Thanks jack,
RANDY put the vin number through for me another thread and it returned what seems to be correct results :/
http://www.skylinesaustralia.com/forums/topic/128496-vins-you-want-fasted/page__st__3020__p__6236563#entry6236563
Im going to steer away from this one, too much confusion is making me uneasy lol
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
