Hi guys trawled the D.I.Y sections and havent had any joy finding any info on my issue pinch.gif
Basically my air con is cold 95% of the time but occasionally just stops going cold and its a PITA.
So ive done the self diagnosis with the climate control and the code 25 has come up which is the sunload sensor near the windscreen apparently
Just wondering if its a big job replacing it and where a new 1 can be purchased?
Id appreciate if any of you fine gentlemen in here can give me some advice on how to replace it or reccommend somebody in sydney who knows there shyte :thanks:
Cheers
Mick
https://www.sau.com.au/forums/topic/391696-r33-climate-control-issue/
I hope you didnt do the test while inside a garage or under shade, that will trigger the sunload sensor warning.
Yes make sure you didnt do this lol
But if you need to replace it, you pop the LHS demister vent (or maybe its the right you can kinda see it anyway) out and unplug the sensor. Not sure where to go from there but should be easy enough with that out of the car and in front of you
The sensor is definetly part of one of the clip in vents that sits in the front of your main dash just before the bottom of the windscreen
Most likely the servo door actuator, very common problem where the cold solder joints in the plug crack from old age/vibration. It will sit there not receiving power on the last selected setting, sometimes a bump in the road etc might momentarily complete the electrical connection and the door will change position.
EDIT: Sorry I get it now lol......
Edited by 89CAL
Thanks for ya input Lance :thumbsup:
where exactly is that actuator located? im a bit lost here........... Does the control unit diagnosis test that too??
Behind the radio, that area. there will be a white rod attached to the servo door actuator (which lets cold or hot air depending on position), best to find it from the passenger side.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
