If I put the headlights in without adjusting the lights are they likely to be aimed correctly? From what I saw it is going to be hard to adjust them afterwards without having to take things off again to adjust.
  • Replies 478
Nearly done with my install. I have one light that has the orange indicator light stuck on. Can anyone tell me what wire it is that I need to cut? I think it is on here somewhere but hey if you know just tell me now :yes:
Green / Red... dont be lazy !!!
All done & looking fantastic. If I can do it then anybody can, it really is an easy job. Has anyone installed new taillights? I have some on order so that is the next job.
Yeah tail-lights are a piece of cake. Remove the trim pieces around the inside of the boot, undo about 5 nuts and the light will come out (with a tiny bit of force, since it is stuck in with goo/sealant). Lights will be plug and play (since they are factory). I am not exactly sure what is involved if you want the boot release on your new lights to work, but go search the G35 forums - I saw a tutorial on how to do it ages ago. If you are going to do it, I have a boot release actuator here brand new in the box that I thought I would need but never did.
Looking forward to getting the taillights. WIll I have to seal them with some "goo" also? I did see the boot release on G35 although I did not look into it that much. I would be interested in taking it off your hands if it is not too hard to install.
Not sure on the "goo", but some residual will remain on the car when you take the old lights out. And sorry mate, I have nfi on how to do the boot release, or whether you actually need an actuator or not. but I have one here just in case - only owes me $50.
Any guys from this group buy want to join in on another? :) Sexiest front bar available imho - and in Urethane not shitty fibreglass.
http://www.skylinesaustralia.com/forums/topic/401873-anyone-interested-in-a-urethane-nismo-v2-front-bumper-group-buy/
There will probably only be 4 bars available.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
