Guest Moses
I am wondering people if you thought a GTR could be sold
with a busted engine and is there anyone who might be
interested. I am getting frustrated with my car situation and
am CONSIDERING the idea of selling this one to lessen my woes.
Would I be better off getting it rebuilt first or is this more money
wasted? I am sure there are heaps of people who would love
to take it off my hands for **** ALL but thats not really what
I want.
Thank You :D
https://www.sau.com.au/forums/topic/39221-i-hate-cars/
Hmmmm.......An interesting one.
I think most "serious" GTR buyers would realise that an engine rebuild is on the cards sooner or later, especially when you start to lean on an older motor fairly heavily.
Me personally? I would have been happy to have had the opportunity to buy my GTR for say $3,000 cheaper (guessing this amount for a BASIC rebuild including parts and labour) as I was expecting a rebuild anyway (although it did come a bit TOO soon).
See how many bites you get first. Good luck dude.
https://www.sau.com.au/forums/topic/39221-i-hate-cars/#findComment-796750
Guest Moses
Well I'm not sure if any keyhole surgery has been performed but I was informed
that the leakdown test told the doctor where it was leaking to. He said past piston no.6 - broken ringland I think. I was hoping for just valve damage as the head has to come off because of the gasket, but that wouldn't cause the blowby that was happening.
https://www.sau.com.au/forums/topic/39221-i-hate-cars/#findComment-798520
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
    • The odometer does go up when driving.  Does this tell it is an issue with the speedometer itself?    Where can I look for replacement cluster? Or speedo? I can likely do the repair.. Will ER34 cluster work on HR34? Or do I need a HR34 20GT S2 specifically lol
    • Mine's a bit bigger at 70x150mm roughly. The spots are flat, just can feel the edges if I dig my nail into it. I did fix some other other ones by both using my finger to sand that small spot (I'm a bit wary of doing this and creating hot spots and a bigger mess) and I also did sand over it flat and others, but this also worried me a bit because if I create an overall low spot on the panel on paint that is good.  Correct me if I'm wrong but as long as it's flat even if I can feel the edges, I can put filler because it will all be level once I sand it? I can see myself going in a circle after sanding guidecoat with 320 grit if for example the panel is flat with my hand but because I sanded the guidecoat I could have created a low spot again somewhere. Unless where I'm going wrong is what I mentioned previously where I didn't go low enough on the grits. It's 1 step forward and 2 step backwards here haha. I'll probably need to experiment with it more. Last time I go back to bare metal lol.
    • Thanks for the details mate , for me I think being a daily driven and happy with a basic tune (630Nm and 310kw) . Seems to be working well I just put on a set of Michelin Pilot Sport 4 should help put the power down. I'm going to start looking a brakes and LSD in the future so I might reach out to you on options to upgrade the brakes. Cheers - Dee
    • I have a HR34 GT... RB20DE My speedo doesn't work! The rest of the gauges seem to work, fuel and RPM. I did not notice if my odometer was going up when driving last.  Any ideas? Speed sensor? Hopefully atleast... Gauge cluster perhaps? Or is that unlikely because the other gauges are working?   Any insight is appreciated. This is a rather new to me car. Lol
