Hey all. I've got one of these fitted to my car. It's been fine. Just the other say I've noticed it's reading seems about lower. It's idling on about 11.0 when it used to idle at about 12 to 13. Cold start reads 10.0. It seems off. Is this normal? would you suspect the wideband or something actually affecting afr's? It's about 3 months old mounted in the stock o2 sensor location.
https://www.sau.com.au/forums/topic/392231-aem-uego-seems-off/
Ill need to get it on a dyno. Just found my car idling with injector duty at 1.0% dropping to .9% then back up to 1.0%. Its odd because it always used to sit at .8% to .9%. Something is throwing out the tune. I have no idea how to clean the AFM so until I can rule out everything else, I'm going to leave the AFM alone for now. Tomorrow Ill pressurize the intake and listen for leaks. If I find none, ill erase the tune, self learn then reflash my tune. If no change, ill set the car on fire. If no change ill clean the AFM.
What would I clean the AFM with? I am thinking after driving back from work just now that it might be something else as the car was flopping a little when I clutched in to about 500rpm. Since I last tested the intake, there were no leaks. I am running a custom metal intake with stock BOV plumbed back and facing away from the AFM(pointing down the 90degree bend towards the turbo.
There was nothing I done which caused the sudden change. The last thing I did was actually heat wrap the dump but that was a while ago and the problem was only noticed a couple of days ago(I keep my eye on the afr's every now and then and it just seemed out of the ordinary).
Edited by SargeRX8
I made a post about this in the Wideband thread in the FI section; I think I have the same or similar problem. My UEGO reads around 10-11 on idle and 12's/13's while cruising, sometimes lower. I'm 99% sure it's not the tune though, as the car drives exactly the same as always and there is no way I'd still be getting 550kms to a tank if my cruise AFR's were 12's. So I think it is either the sensor that has failed, OR there is a bad connection somewhere.
I haven't got around to pulling out the sensor or checking connections yet, so I'll let you know what I find when I do.
I'll get it out tomorrow make sure everything is nice and tight. Pretty unfortunate if it is the sensor. Only a couple months old ffs. I wish I bought the innovate unit which can be calibrated when it reads off.
I'll try everything to see if slowly something makes a difference. It reads 10.0 on cold start, that is the lowest reading the unit can display. If that was the case I should be fouling plugs in the 9.x region...
After alot of reading about installation locations, I decided to fit it in the standard location where the thing normally goes. I don't think this should cause the unit to fail after 2000km of use... People have had theirs on their cars in that location for years Ive read with still consistent readings. Car doesn't get a hard time. I'm never constantly giving it stick. Maybe to overtake or just a little squirt here and there but nothing out of the ordinary. You can tell I drive like a bitch when after 1.5 years and about 30000km of driving, my kuhmo tires were on 70% lol and they came on the car.
Edited by SargeRX8
Maybe you should go give it a thrash and see if that helps. There might be a carbon buildup on the sensor or something. Alternatively pull it out and have a look at it. See what reading you get when its in freash air
Mine has been fine since I put it in about 6 months ago. Reads exactly how the wideband did on my dyno run and the wideband used when it was first tuned.
But mine is in the suggested install location right about where the gearbox crossmember is
Where did you earth the gauge to? I dont think that will be the problem but check the earth is O.K anyway
Fresh air I think it will fire all the way to lean, it does it when the ignition is on. Is there anything I can spray on it to clean it or is that not an option? Ill try take it for a little push later get some heat on it to try clear and burn off some of the carbon. Can't remember where I grounded it but Ill double check it.
Is there enough room for it to face the right way when you mount it under the car? Did you point it straight down or from the side.
no you dont.... you'd be on your 3rd unit by now :rolleyes:
What a load of crap, I have been running my innovative for over two years on the same sensor and it still reads perfectly, they obviously fixed any issues with them a long time ago. I even bought one cheap, ($50) from the for sale section and got it working again, then modified it with a USB input.
Its been a good unit, if a little too fast in reacting according to my tuner. He would prefer to have the output smoother while tuning but I can only set it up for 1/3 second refresh max in the software.
mine points slightly up and in (just about hits the gearbox crossmember) but its about where the instructions say to put it
Contact cleaner would probably be alright if you unplugged the sensor, cleaned it and let it sit for a few mins before putting it back in. Probably just better to take it for a thrash but, I dont think contact cleaner would worry it but just in case
yer some of them are fine, but theres plenty of people (myself included) with several dead innovate units, through no fault of the end user a lot of them seam to have internal circuit failures, bad solder joints etc.
in open air it should rear around 20-21:1
Yeh the UEGO maxes at 18.5.
It will go to that in open air though. To test it, spray some brake cleaner on a cloth and cover cover the sensor with the cloth. It should go full rich to 10 and stay there. If it goes back to lean then it's stuffed.
Edited by Hanaldo
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
