  • Replies 162
maybe a new photo? just to make it easier to identify whats gone and left.
P.s whitestag, you sir have a nice whip. Very nice!! QX1 is such a nice white on stags
In the photo the car looks the same all body panels wheels are still available. The wheels aren't on as I've sold parts of the suspension. Oh and rhs taillight is gone. Most of the stuff sold can't be seen.
The wheels are in very good condition, looking at $300 the set, Tyers are dried up.
QX1 the only colour that counts... * awaits flames*
Damn right, in the sun when its clean its even better!!! I hate the it costs so much when it come to mods/repairs because of paint but in the end its so worth it.
Apologies all no intention in misleading anyone on hear I bought the car for the engine and now selling the car for parts I was advised it was a series 2 but I maybe wrong
hey mate i know you said you purchased it for the engine but you wouldnt have a spare turbo lying around would you?
Edited by loymclure
i dont have one its N/A
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
