Hi All,
I'm in the process of purchasing my very own 'zilla, and I really need some help with wheel size selection as I'm getting some rims made to spec.
I've read quite a bit on here and other forums, and I think I have a reasonable idea of what I want/need.
This car will be for street use, and I'd like the rims and tyres to sit *just* inside the guards, or maybe flush, but definitely not proud of the guards. At this stage I don't want to roll or lip the guards.
I would like to run 18x9.5 or 18x10 all round with un-stretched tyres, so I'm just trying to determine what combination of rim size and offset would achieve the desired stance. From what I've read of similarly-configured R32s, I think the offset needs to be about +20 - +30.
For reference the suspension includes HKS Hipermax coilovers & Noltec adjustable front upper control arms, brake rotors are DBA 4000 with standard calipers, also equipped with a Tomei HICAS lock.
Cheers!
https://www.sau.com.au/forums/topic/392503-18-wheels-for-an-r32-gt-r/
I know 18 x 10 +22 will sit flush (Directly under your guards) with some negative camber.
A friend of mine has BBS wheels in that size with HKS Hipermax coilovers and looks great.
No guard work needed as he has just lowered it till there is no wheel arch gap.
Thanks Hank and Skyline,
It sounds like I need 18x9.5 with +15 offset, 'cos I want to keep camber neutral.
Am I right in saying that to move the wheels further inside the guards, I would need to increase the amount of offset?
Yes, the higher the offset, the further the wheels sit in.
18 x 9.5 +15 will sit nice.
Since 18 x 10 is half an inch wider, it will poke out just a tad, so you have to raise the offset to +22 to make it sit back in flush again.
Skyline you are a scholar, and possibly a gentleman too :D
Thanks for your help, I'll be sure to post pics when the car is finally in my possession and sporting the new footwear.
Cheers!
All good :D
But, if you can, test fit the wheels before buying them.
Always, to see how they look and fit and go from there, before buying them.
All good :D
Hmm might be hard considering I need to pay a deposit for ADV to start the build...
Useful! Thanks again..
Ah I see, haha!
Also check out GTR - Owners Club UK, those fella's seem to have an idea and is quiet a good site, mainly for GTR's.
Or Google search:
This came up on Nissan Slivia.com
18 x 9.5 +12 = Looks flush to me.
An inch or two lower at the front and it'd be even better.
GTROC UK is pretty good actually, they've got a large 'show us ya wheels' thread there too...
Yes those Kais look pretty good with the +12 offset.
It's confusing and hard to judge because I've seen quite a few cars with similar wheel specs. So I guess the variations are all due to the varying ride heights, suspension setups and tyres..
Yeah man, best go there and use them as samples to see what looks best.
Or if the guards are rolled / lipped / flared.
If you stick to the 18 x 9.5 +12 / +15 or around about that fitment, you'd still get something good.
+22 is the "correct" fit.
I've read a lot that +12 will be fine on a 18x9.5 rim, BUT there are many suspension factors that affect fit. On a stock lowered car +12 might be fine. But when you start playing with camber and caster and aftermarket suspension arms, it all goes out the window.
I have 18x9 +30 R34 GTR rims, and if I add the quarter inch plus 18mm I get the outside of the rim sitting 24mm further out. On the rears of my 32 GTR, given my suspension settings (and other factors such as 3piece rotors with a thicker alloy hat pushing out the hubs marginally), this will protrude the wheel outside the guard. Now I could tip some more -ve camber but it is set up to handle, not to fit a set of wheels in. So unless I want to compromise the suspension set up, +12s will be too wide.
On the front, the +12s will fit fine in terms of not protruding from the guard. However, as I have a stack of caster, the front wheels are further forward in the wheel arches than stock. Therefore as you turn the wheels, the outside edge of the tyre/wheel catches the front of the inner guard. If you increase the offset, this will mean the wheel will contact the inner guard with even less lock applied. So again, I don't want to change the suspension geometry to fit wheels, I'd rather get the right fit wheels to work with the suspension set up that is currently set up for handling.
hope that helps.
hope that helps.
Thanks for taking the time to add that info Ronin, definitely helps clarify and confirm my thinking.
So for the time being I believe I need +22, possibly up to +25 like the 18x9.5 Bee-R wheels.. but I won't really know until I take delivery of the car, and have the opportunity to test-fit some wheels with the same specs.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
