Hi all its time to part with my gtr but all for a good cause to buy a house so here it goes.
$25000 Neg
The car is a 1989 R32 gtr skyline with a fresh built that Paul from Red R racing put together here are the details.
R34 gtr crank
CP 40 thou pistons with modified eagle rods
Hks oil pump and trust sump with modified oil return and restrictor fitted
Tomei Pon cam type b's and valve springs and retainers
tomei adjustable cam gears
spit fire coil packs
2860-5 turbos with r34 gtr stainless dumps and veil side front pipe and a varex muffler
The car produced 430 hp at the wheels with a Guilt toy tune. There is plenty more left in it with a less restrictive exhaust.
The car is also fitted with 18*9 +15 lenso DR1 rims.
JJR adjustable camber arms front and rear with bilstein coil overs
Top end sterio kenwood head unit, JL splits and JL rears $2000 worth alone come with sub and amp just havent gotten to fit it yet
Viper alarm is installed
there is probably other things i have forgotten to mention but feel free to hit me up
My number is 0434108477 feel free to ring me or txt me.
thanks scottie
https://www.sau.com.au/forums/topic/392657-built-r32-gtr/
  • Replies 45
List what ecu injectors fuel pump/ system. There is more mods to this car than what u have stated. Having a red r racing engine u know it one of the best.
Nice car and its well worth the low 20s
https://www.sau.com.au/forums/topic/392657-built-r32-gtr/#findComment-6247001
Sorry like i said alot to list it has and cheers i think i have priced it fairly like i said i am negotiable oh and the motor is 8 000km old
HKS 1000cc injectors bosch 040 fuel pump and a power fc with hand controller
https://www.sau.com.au/forums/topic/392657-built-r32-gtr/#findComment-6247010
Long engine alone is well worth half the asking price. Plus all the bolt ons someone wil get a good car by the look of it.
I have 2 gtrs if I didn't already or had a spare lump of cash would buy this just to save on the engine hastles of an unbuilt engine or unreliable engine built by some shop that don't know the rb engines.
Paul is one of if not the best rb engine builder in the country in my opinion.
Good luck with your sale ill spread the word of a quality gtr for sale
https://www.sau.com.au/forums/topic/392657-built-r32-gtr/#findComment-6247270
hi it is running 21 psi atm and the turbos where brand new when the motor was built so they have 8000km on them they also have the oil restrictor fitted in the banjo lines to. goz1llaaa34 yes there is alittle bit of rust i will post some photos for you tonight and interior pics will be put up as well thanks for the interest guys
https://www.sau.com.au/forums/topic/392657-built-r32-gtr/#findComment-6247366
Thanks mate, does the air con work ?
Hey sorry mate air con does work but needs to be re gassed which i can organise it to be done and here is acouple of interior pics
https://www.sau.com.au/forums/topic/392657-built-r32-gtr/#findComment-6248436
Could you please tell me where exactly are the rust spots? So that I will have a clue. PM me if you like...
heya sorry mate i completely forgot about that here are a couple of photosof the rust. the rest of the body is straightas with only like 2 noticeable dints. There no rust in the sills or under body at all. I was quoted $3000 for the rust repairs with all the windows removed rust plated and the roof and rear quarters repainted. Other than that and the front seats being average the car is in very good condition and i forgot to add it has a Jim berry single plate custom clutch also which i would have to say is the best clutch i have driven.
https://www.sau.com.au/forums/topic/392657-built-r32-gtr/#findComment-6253182
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
