  • Replies 55
Posted Images
You just need to join a game a mate is hosting, head to the chest, and open.
It'll use your key, but you'll be able to open it as many times as you have the patience to do so.
AFAIK, it only works for the guest, not the host, so if they want a go, you'll have to switch places.
Level 45 by the time I got to Wilhelm in play 2.
Finished the first run at 35.
Gaige is a pretty entertaining character. Decent through put for her levels, and DT is a f**king tank, I can see him being insanely useful with the right build. Only problem I see with him is the lack of ability to call him back early.
This.. and also accidentally reloading when intending to interact/travel/buy etc... thus losing all of the built up Anarchy :verymad:
Edited by iamhe77
Ha, yeah, that shit me a bit.
Gave anarchy a spin, pretty useful, though after a while it's like throwing a bucket of rice at a ping pong ball 50ft away. Need to experiment with some Hyperion weaponry. It's not bad though, with a triple barrel Jakobs, I could run right up to a BA Bullymong and one shot them.
Gonna re-spec for a support build until level 30ish, and then go for a hybrid high DPS build.
Had my first Terra kill the other day, took 3 attempts until he dropped the Commando com, and he dropped the Mecro com on the very next kill. Still chasing the rest of his legendaries unfortunately...
If anyone on Xbox has a Hide of Terra, Breath of Terra, or a shock Conference Call or shock Sledge, and wants a level 50 Pyrophobia in return, shoot me a message on XBL, my GT is scarecrowAU.
Duped, legit, don't care as long as it isn't modded.
Yeah level 31 now with Commando and still is a good challenge and enjoying the game. Dont think i will play through again but definately keen to see further DLC's for it.
Cant beleive i took 3 weeks of annual leave to play this for sometime and some of you guys are on your second way through. In my defence i have completed all but one side quest so far.
Most of my add ons are for the turrent cool downrate, so basically means less time for me to have to wait for the turrent to be used again. Sometimes it is a case of deploying it and running away for it to take care of everything but that only works to a certain level.
I've been lvl 50 with Axton for a little while now, about halfway through his second PT. Been soloing Terra for way too long, picked up a couple legendary items for my troubles, Including a Legendary Soldier com adding +5 to all tier 1 skills, huge bonus for cool down rates, fire rate, and gun damage. It's pretty sweet. Haven't played him in a few days though. Got massively sick of farming.
Side note, anyone thinking of farming Terra, I cannot emphasise enough just how easy a x7 Conference Call and a Bee shield make it.
Up to level 28 first PT with my mechro build. Invested pretty heavily in the Little Big Trouble tree. Should prove rather handy by the time she hits her second, where every enemy seems to have a f**king adaptive shield.
I've got a bunch of free time (hospitality worker), so a lot of that gets dumped into BL2 at the moment, but I'm still yet to see PT 2.5 with either build, yet so many people on the GBX forums have maxxed all 5 characters. Crazy.
Latest patch notes.
Update 1.2.0 (Released 11/13/2012)
  • Fixed fast travel stations from downloadable content sometimes disappearing when loading a saved game.
  • Fixed an issue where players could occasionally be unable to connect to one another if one of them had recently been in DLC that the other doesn't have.
  • Fixed an issue where players were sometimes unable to pick items up after another player had bulk-picked-up a nearby item.
  • Fixed a bug in the inventory UI when quickly scrolling to the bottom of a list using the mouse wheel.
  • Improved PhysX fluid rendering quality at high resolutions.
  • Improved NVIDIA 3D Vision integration.
  • Fixed the "Inverted reverse steering" option not working for clients in a multiplayer game.
  • Fixed the player's backpack sort setting not persisting.
  • Fixed an issue causing players to sometimes crash or freeze after killing Master Gee in the Captain Scarlett DLC.
  • Fixed challenges showing inaccurate completion amounts for area-specific challenges.
  • Fixed a bug where the player's active mission would sometimes fall back to main-game missions when completing other missions in DLC areas.
  • Fixed a bug that could cause players to lose mission rewards that they had not claimed when switching between Normal mode and True Vault Hunter mode.
  • Added a confirmation dialog when opening the golden chest in Sanctuary.
  • Fixed Arid Nexus Badlands showing an undiscovered challenge that was not attainable.
  • Restored some lost progress to players who have had their profiles reset. To ensure you are credited for as much progress as possible, please load your character, select "Continue" on the Main Menu, and then "Save and Quit" after you enter the world. Repeat this process for each character in your character list.
  • Fixed the Mechromancer's Anarchy skill sometimes losing stacks incorrectly for multiplayer clients.
  • Fixed a bug causing players to sometimes get stuck zoomed in when in "fight for your life" mode.
  • Fixed challenge "For The Hoard!" to work properly after resetting challenges.
  • Fixed a bug that could sometimes cause players' skill points to be reset when loading their character.
  • Fixed a bug that could cause enemies and missions to be locked to an incorrect level.
  • Fixed bug causing Tediore reloads to get Amplify shield damage bonuses for each round remaining in the clip.
  • Amplify damage from Amplify Shields is now divided among all projectiles fired from a single shot.
  • Balance adjustments to "The Bee":
    • Increased Recharge Delay
    • Significantly increased Recharge Rate
    • Reduced Amplify damage
    [*]DLC raid bosses no longer drop Seraph crystals in Normal Mode.
    [*]Reduced level of DLC raid bosses in Normal Mode.
    [*]Fixed issue resulting in infinite leveling exploit with Fleshstick.
    [*]Increased the health of Terramorphous, Willhelm, and Blue.
    [*]Additional miscellaneous balance tweaks.
    [*]Fixed issues with the following missions that could cause players to get stuck or not be able to complete them:
    • Plan B
    • Wildlife Preservation
    • Mighty Morphin
    • Animal Rescue: Food
    • The Man Who Would Be Jack
    • Get To Know Jack
    • Where Angels Fear to Tread
    • Trailer Trashing
    • Clan War: First Place
    • Stalker of Stalkers
    • The Once and Future Slab
    • Home Movies
    • Shielded Favors
    • You Are Cordially Invited: Tea Party
    • (Captain Scarlett) Freedom of Speech
Interesting read on the GBX forums, a lot of the patched bugs are still bugged, and the horrifically nerfed Bee has effectively doubled the tedium of end game farming. Hooray. I think I'll be leaving my console offline for a while...
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
