Hi guys,
In the process of stripping down my GTR, to find out what I have and where improvements can be made. Stuck as to what turbos these are.
Firstly GT2560R. Have read they are re badged 2860's?
Does the 707160-0005 mean I have "-5's". If so why am I so down on power (306.5awkw) when considering its a fully built engine, 260/9.15 tomei cams, PFC, EBC bla bla etc... Could it be a poo tune?
Thanks for the input guys.
Ben
Edited by TrikkBen
They are -5's. That family used to be the GT28 series but Garrett for some reason renamed them (-5's, -9's, -7's etc) to GT25 series.
As for power, need more info: who tuned it (does the PFC actually have a tune on it or is it running a stock basemap), how much boost your running, dyno sheet with AFRs etc
Tuned by RevZone (previous owner). Don't know how to tell if its a base map or tune, I would think it has a tune.. Max boost is 20psi/1.5bar. Dyno sheets do not have air/fuel on them..
LOL @ back yard engraving. this is what a proper garrett turbo id tag should look like mate;
best option is to take it to a turbo specialist and get them to check it out so you know 100% what you're running, or ring RevZone and ask for details on the car??
Woah...
I think I might work out what they are and stick them up for sale, I was going to change them anyway.. The seals are gone.
What would something like these be worth, provided I find out what they are and taking in to account they need seals?
Thanks for the help guys, had me baffled all weekend..
Ben
if they need seals they honestly arent worth much at all..
i think a rebuild with seals will start at a bare minimum of 400 each through hypergear, assuming nothing is damaged. the price could go up from there up to 800 each. realistically if they arent genuine its probably a waste anyway..
better to have a look here and buy brand new genuine units:
http://www.skylinesaustralia.com/forums/topic/229588-gtr-turbo-upgrades-garrett-gt2860r-5-7-9-10/
more expensive but you know what they say, do it once do it right
I already plan it buy new ones. I ment how much would I put the on eBay etc. for?
I'm not keeping these as they don't seem to have the balls to make the power I want.
I will definitely buy new units, one unrelated question, may aswell ask while my thread is active. Would I have to change the actuators on the new -5's with the boost I'm running (1.5bar). I have a profec b ebc..? Do you normally upgrade the spring/actuator for 350-400kw's?
Edited by TrikkBen
Yer, both the same. Could both do with a rebuild.
I pulled he rear turbo off and may have found a problem? The actuator rod was not adjusted at all, so the WG is free floating by about 3mm. You can wiggle it around and lift it off the seat.... Surely thats not right as the front doesnt do it. Could this be a helpig cause of my lack of power?
Thanks
Ben
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
