Anyone had any engine detailing by these guys or know of anyone else, want to get my cars engine bay looking like stephans R33 GTR on the home page, instead of a stock engine, something like out high performance imports, all chromed up and shit.
https://www.sau.com.au/forums/topic/392954-pro-race-products/
Man that sucks if they have closed up shop, that place looked really professional. Does anyone know why. What about hyperdrive do they do that sought of thing aswell. Was looking at spending a couple of g's
Something along the lines of them spending too much time on there own cars, and not enough running the business, which meant it was losing money.
Could always give Andy a call and ask, but I have a feeling they are too busy with their other work. Still worth finding out.
Have you thought about Beyond Custom in Morley? Have seen some fantastic cars come out of there.
Hey everyone, getting this engine bay thing sorted by chronic customs, checked them out last week and have a really nice clean shop front with all things you could want for your car plus a huge workshop, hopefully all things go well then would definatly recommend them.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
