Thanks for saving me a pit spot guys, much obliged.
Was a very mixed bag for me. Car made no extra power after going from a smaller turbo on 14psi to a larger one on 17psi, filled the catch can twice, leaked out the back of the rocker cover and handled like a wet sock all day. Only managed to shave 3 tenths off my PB. I'll be compression testing shortly as I have a feeling the engine is showing its 23yrs and 145,000ks of age.
Could have been worse, got there and back in one piece and got to do some testing on setup and learn a few things the car needs and despite all the hurdles still managed to go a touch faster.
EDIT: I've sent an email to Adam about those VL drivers. I almost had the front of my car ripped off a number of times. they don't signal to pass and will drive across into your line without any hesitation. Also happy to go two wide, and sideways, through corners if you get up beside them.
I don't mind pushing harder and doing that sort of thing with mates but not people who drive like lunatics who clearly aren't watching mirrors plus it's not a door to door racing event.
Edited by ActionDan
There was an incident in one of the last sessions wasnt there?
Dont know the full story but it sucks when that happens at the track. Especially all the way out at Winton.
Hope all involved got there cars sorted and made the journy home.
Cheers all to a good day though.
The poor RSR's wernt up for the challenge but still had a lot of fun!!
yeah around 4:30 2 cars made contact. Unfortunately one of them a SAU member.
Short of it was one of the Honda's spun at the sweeper and went into the side of the SAU members car.
some bent arms damaged rim and panel damage ended his day.
no-one hurt thankfully.
Damn, sorry to hear that to whoever it was.
Martin you might remember me lamenting having so many Honda drivers in my group, the first 2 sessions were more a case of self preservation than going for outright lap times.
I got this from Adam re the VLs
"Hi Dan,
The VL’s are a group of people that come from Bendigo. They are generally pretty good, but on the weekend they had a couple of new drivers, but they were allocated into the Beginners group. I will have a chat to them and tell them to be more careful on the track. Obviously we want everyone to have an enjoyable experience so I am glad you took the time to email and let me know.
Part of the problem is the way we run the groups. I am working on a new process that we can easily identify which driver is in which group, so that our man on the track entry can control it better.
We are always evolving, or trying to anyway.
Cheers
Adam"
Much love to the SAU crew for sticking around and making sure I was all right and helping out. The car is messed up bad and it's going to be insane to repair it now. I'm just lucky that I noticed him lose control and managed to react quick enough to try to avoid it, otherwise he would have hit me right in the drivers side door.
Other than that, the day was great and was a lot of fun. I've uploaded all my photos for the day, check them out here. Took a photo of pretty much every car. :)
Mate that's no good about the damage and you managed to get 0 photos of my car but that's cool :D
The silver Evo5/6 in those pics, if you know the driver, tell him that I apologise for not seeing him coming sooner down the back straight. He might remember my S13 green/grey and big wing. I was on a cool down lap and checking guages etc when he was coming up behind me and I may have inadvertently caused him to brake earlier than he wanted to into the chicane.
42secs - footage of me on a cooldown lap yay :D I remember seeing that Evo roll off the road and wondered if he wasn't watching where he was going or had something bust as he wasn't going that quick and I'd followed him through there a few laps before at higher speeds.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
