When I start my car up AT light goes on and then off straight away....
Whilst driving for about 10 - 15mins AT light comes on, gears jam up and as i put my foot on accelerator revs go up, but i dont go anywhere maybe like 20 kms at most.
I then turn the car off and start it again AT light goes on and off straight away, car changes gear but it still doesnt feel quite right. The same thing has happened twice now, i am taking the car to my mechanics tomorrow to have a look, he said he has never heard of the problem and thinks it may be an electrical problem and will have a look at the computer.
Has anyone heard of something like this? Im pretty worried.
I recently had the car serviced as well as a transmission service too.
But i havent driven the car in the last week which did cause the battery to die, i recharged it and the car started, but would the battery dying affect the transmission?
Thanks
Check out MV Automatics, best place to get jap autoboxes looked at.
I would be suspecting the transmission service, what fluid did they use, was it Genuine Nissan fluid or wasn't genuine, if it wasn't genuine did it conform to the correct fluid that autobox requires (Matic-D, Matic-J etc)
ok. on Wednesday I drove it up to my mechanics in the morning, nothing was wrong, no AT light...perfect drive.
My mechanic calls me up during the day, says the car is running perfectly, he took it for a drive, says it was good. He said that he'll keep it overnight, and have another look, and drive tomorrow....all good nothing happened.
I then get it back and drive it home, I thought that was it.
I just drove it, the problem is back. I had to stop and start my car 3 times to get back home. Im getting sick of this, I cant even drive my car.. What could be the problem?
I think its an electrical fault somewhere it has to be.
If u can imagine me starting the car, drive it down the road...then all of a sudden AT light comes on, gear changes and the car wont accelerate....WTF?
*If i put it in tiptronic after the AT light comes on, it is in 4th and wont change, till i stop and turn off the car.
***when my mechanic had it, the only error code that came up was something to do with air flow, but that didnt seem to be a problem he said, as he took it for drives and said it was running great...he said that it would most likely be a faulty sensor, and not to be affiliated with the A/T problem
Edited by Jα©òβ
If your mechanic is using a generic fault code scanner and it is returning code 070 (with a description that says INT/VOL or something similar) then it is not correct, and is in fact a fault from the traction control system. Alternatively, it could be a TCU fault. I have seen this happen on an R34 ECU using a generic scanner, but when you connect a Nistune laptop to it and look, it comes up as the correct fault (for the car I was looking at) where the traction control throttle motor switch was not being triggered. Anyway, the lesson here is that the generic code scanner could be telling lies.
been looking on other forums and stuff and it appears that people that have had the same or similar problem, have performed an auto diagnostic test:
R34 GTT Tiptronic Self Diagnostic
1. Warm engine.
2. Turn ignition on-off more than once and then leave OFF.
3. Turn ignition ON with selector in "P" position and ensure A/T warning lamp is ON for 2 seconds.
4. Turn ignition OFF.
5. Depress brake pedal and move selector to "D" position.
6. Turn ignition ON.
7. Release brake pedal and move selector to "3" position.
8. Depress brake pedal with left foot and depress accelerator pedal fully down with right foot and move selector to "2" position.
9. Read A/T warning lamp flashes for codes.
R34 Tiptronic Codes
After a long initial 'start' flash, the A/T lamp will flash through it's full code sequence (RB20DE 10 flashes or Non RB20DE 13 flashes), but any faults will be shown by a longer flash on the relevant code number. This sequence will then be repeated until you turn the ignition OFF.
1. Vehicle speed sensor 1
2. Vehicle speed sensor 2
3. Throttle postion sensor
4. Shift solenoid A
5. Shift solenoid B
6. Overrun clutch solenoid
7. Lock-up solenoid
8. A/T fluid temp. sensor, TCM power suply or throttle position sensor power supply
9. Engine speed signal
10. RB20DE Line Pressure Solenoid or Non-RB20DE Turbine Sensor
11. Non-RB20DE Line Pressure solenoid
12. Non-RB20DE Total control signal
13. Non-RB20DE Shift control unit
No flashes:- PNP idle switch/full switch or RB20DE Overdrive control switch or Non-RB20DE Stop lamp switch
A lot of the forums have said that it is probably a faulty solenoid, or something to do with the solenoid. Does anyone know if this is expensive to fix? Is it a big job?
As the car is really not drivable without me stopping every 10mins, I wold rather someone to come out and fix the issue, is there anyone in Adelaide that specializes in transmissions and is able to come out?
  • 3 months later...
my gfs does the same thing. and its also intermittant. hers may drive fine for weeks and then it goes into a/t mode. have u run the gearbox diagnostic test and written down the fault code/codes? if so which codes have come up? urs sounds like an easy fix because it is happening so frequently. check the codes n see what it says. another thing if the throttle position senson stuffs up it triggers a/t mode which sounds like ur problem. to check it u need to check the correct pin on ur tcm/ecm with a volt meter and it should read .5 volt with throttle closed. if it reads 5v then its stuffed but u will need to check it as soon as the a/t light goes on. let us no how u go.
  • 2 months later...
My car has just started to throw the a/t light at me in my gtt. It has only happened twice both times on the freeway with cruise on and 1500km apart . Did you guys have any luck? Im going to change the fluids in the next week or am i wasting time and money. anyone know of a good auto center on the central coast nsw.
my stagea started doing that when we removed the battery while waiting for new turbo to arrive. A week later once new turbo was installed driving to get nistune and on the way it just stopped, no acceleration and unable to steer.
Has only now happened for a couple of days but since then has not come back. This issue happened with stock computer and with new computer with nistune board.
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
