How old are u slylinerz???
Jeesus - have I been wasting my time here for over 4 years...
Mav - bring up another shitty old thread and you're banned.
hahahaha mate that comment made my night.. TOPS!!!
Best thing is the amount of ppl who have now pointed out their age...
Let alone what they were doing back in 2002 :D
  • Replies 241
There's several threads on SAU dedicated to the 4 door...
at the end of the day if u need the car to pull chicks, then...heheh yeah.
Mate I'm with you.....when you leave the car and go into the bar, what you gonna do? Pull out your wallet and show her a picture? :(
Mate I'm with you.....when you leave the car and go into the bar, what you gonna do? Pull out your wallet and show her a picture? :laugh:
lol, im sure there are some people here that dont dont actually go into the bar.. rather they park out front and call out from their car.
To make this thread timeless, we should put our year of birth :P
26 for me and born in 1980.
And back in 2002, I was a mere immigrant boy trying to earn a crust in my first IT office job. Beats working down the mines with donkeys from 100 years prior in the UK :P
