Sorry for the newb question
but could some one give me a simple diagram (like xxxx > xxxx . xxxx etc)
on what happens when you boost
like where it goes from the turbo with specific reference to fmic and bov (which where my boost guage is connected)
got a boost leak
if i can understand this it will prob put in right place to look
thanks
https://www.sau.com.au/forums/topic/394511-how-boost-works/
So what ur saying is-
U want to know how to find a boost leak ?
U want to know how a turbo works ?
U want to know the routing of R33 intercooler pipes ?
Also u mentioned a BOV, if its an atmo one dont bother. It Will only cause u idle and fuel economy issues. Stick with the stock one.
https://www.sau.com.au/forums/topic/394511-how-boost-works/#findComment-6271426
hahaha but those pages dont seem to answer my question
and want it more answered towards a r33 style turbo set up
not some home made science project
please read the question before posting thanks (not just the post)
Oh, well in that case, let's start with this:
My link
After you've read that, then read Messiah's post, then refer back to my first link. After all, can't run before we can walk ;)
https://www.sau.com.au/forums/topic/394511-how-boost-works/#findComment-6271444
URM OK
THOUGHT THE REPLIES WOULD BE LOT MORE USEFUL
HANALDO WHICH ONE OF THOSE GOOGLE RESULTS ANSWER MY QUESTION?
AS I CANT REALLY FIND WT I ASKED IN OP
OK WHAT I WANT TO KNOW IS WHERE THE BOOST (AIR) FLOWS FROM THE TURBO?
ORIGINALLY HAD A BOOST LEAK BUT I KNOW IT WAS COMING TO THE BOV (AS THE BOOST GUAGE IS CONNECTED AROUND THERE AND I DID HAVE FULL BOOST READING)
I DID LOOK INSIDE AND SAW THE FMIC JOINING AT THE FRONT WAS DODGY (SILICON JOINERS ANID CLAMPS), REMOVED THEM AND REALISED I CANT PUT IT BACK ON WITHOUT REMOVING HALF OF THE INTERCOOLER PIPING (WHICH I WILL DO LATER)
NOW I HAVE NO BOOST BUT IM HOPING ITS JUST BECAUSE EVERYTHINGS LOST AROUND THE INTERCOOLER
SO THE REASON I ASKED IS SO I CAN KNOW WHERE THE POSSIBILITIES ARE IF ITS COMING BETWEEN THE BOV AND ENGINE
AND JUST TO MAKE SURE THE FMIC COMES BEFORE BOV, OR MAYBE I HAVE ANOTHER PROBLEM
IF YOU CANT HELP ME WITH THIS OR ANSWER MY ORIGINAL POST, DONT REPLY
I KNOW HOW TO USE GOOGLE
NO NEED FOR SMART ASS COMMENTS (YES I KNOW I POSTED EVERYTHING IN CAPITALS - HOPEFULLY YOU CAN READ IT CAREFULLY BEFORE REPLYING)
https://www.sau.com.au/forums/topic/394511-how-boost-works/#findComment-6271495
I think i know what ur getting at, u wanna know which is the outlet pipe off the turbo ? Look at ur engine from the front, u will see a big cross over pipe and a pipe connected to it, now look below that pipe and u will see another one that sorta runs parralel. Thats where the boost comes from, the lower one of the pipes, if u follow it back to the turbo u will see a 90degree elbow, thats ur outlet from the turbo.
https://www.sau.com.au/forums/topic/394511-how-boost-works/#findComment-6271535
Nope, now I can't read it at all. I read this part. And now my reply is probably pretty useless, because I doubt the rest of your post was in relation to your ill-use of caps lock.
Honestly mate, my first post was helping you. If you don't understand how these things work then you're not going to be able to find and fix problems. It seems pretty clear to me that you don't understand because you are asking a question of something so simple. So do us, and yourself, a favour by reading about how these things work. A Skyline isn't inherently different from any other turbocharged/intercooled engine.
https://www.sau.com.au/forums/topic/394511-how-boost-works/#findComment-6271672
At risk of feeding a very hungry troll...
it should be pretty simple to relate which pipes go to where.
start at your air filter, follow it back to the turbo, air goes in there. gets compressed then leaves the compressor housing (silver bit) then through to the intercooler, cools its shit down, then up and around past the BOV and to the throttle body -> engine.
p.s. i found that pic in 3 clicks and 11 key strokes...
https://www.sau.com.au/forums/topic/394511-how-boost-works/#findComment-6271756
Guest
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
