Go with what you have then...gotta keep the teacher happy ;)
Duncan
the extract, for educational purposes only (copyright) is from Race Car Engineering and Mechanics - Paul Van Valkenberg, HP books and is available from http://www.bevenyoung.com.au/prdt393.htm
I can put a bit more res in, but it will be larger. Give me a couple of hours as the other half is wanting me to do a couple of things.
Great post skylinegeoff. Im currently studying 3rd year mech eng and am also interested in getting into race engineering. How did you go about finding more info about getting into the field? Also, can you recommend any other books etc that are worthwhile to read on the topic?
repost of images. the rest of the article is very race specific so I have left it out. Seriously recommend buying this text due to the broad nature. Also just good reading.
Rhett
try a search and look through that website I posted for the book. Also look at a mag called Racecar Engineer.
In melb there is Kangan Batman TAFE that runs a tech course in race mechanics as well as race engine building...worth a look. Some of the uni's have automotive engineering undergrad degrees but couldn't help me with a masters in race engineering or any of the other areas I am interested in such as automotive management.
Searching online you will find a fair amount of info as well. There is also a member on the forum who is highly experienced in race car dynamics and engineering, as well as managing a team (if it still operates after PROCAR closed down) but I won't post his details to prevent him getting bombed with questions. He already does enough and if you are truly interested you will be able to deduce his identity, or he will announce it himself, probably as he adds a mountain of relevant info to this thread.
Majanal : You wrote somewhere that you have a few suspension goodies... From a non scientific perspective, what sort of difference did good suspension make to your drifting? What difference did the locker make?
Ok, sorry about the slow reply.
I found that the suspension made the car behave in a much more controlable way, I was able to predict what it was going to do, which was sometimes "oops" lol. Made the whole car much nicer to drive and by the end of the day I was pretty much able to link the whole track.
The locker helped also as when I flawed it on the flick back it would spin both wheels instead of just the one and therefore give again more control, sounds backwards I know, but when you have one wheel spinning and one gripping it really sucks, as you have to drag that tyre around with you.
Hope that helps, if not, please feel free to ask specific questions and I'll do my best to answer!
Dan.
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
