I dont believe they are.... However its worth a check just incase, i think the body shapes are different which means the flanges wont line up :(
Well they look quite similar in shape:
But I doubt a 44mm gate will fit onto a 40mm v-band? My setup is also relatively tight, so I doubt a 44mm gate setup will fit. Also might not be a good idea to get the tune done using a 44mm when I plan on using a 40mm, not sure how much it would affect flow and efficiency, but possibly a fair bit. Thanks though mate!
My tial mvs 44mm is smaller then a normal tial 44mm. So maybe able to try one of them? Could turbosmart email you the specs of the sleeve and get one machined locally?
Yehhh they won't, they want the money themselves which is understandable.
Just had a real good look around the shed and it's no where to be found, so now the quest begins to find one I can borrow this week! :/
I think its only the diaphragm bit thats different, the body still looks similar man!
Good luck mate, i hope you find one!
Updates in here hanaldo
He hasn't got a leg to stand on :P
No really, both the car and him were undergoing work yesterday so updates may take a day or two, hope it's good news on both accounts :D
Haha will hopefully update later today lads, surgery went well but unfortunately I won't be able to drive for a few days :( talk about a tease!? trying to sort out a couple of mates to drive me in and drive the car home. Sort of have to, tuner doesn't have space to hold on to it :/
Glad to hear it went well mate :D When is it going on the dyno? Yesterday? Today? Dont hold us in suspense for too long :P
Haha oh I thought you'd seen the Hypergear thread. The car is all done, it was the only car my tuner had to tune yesterday. He texted me this last night:
"Car went OK. Didnt ooze hp unfortunately. It doesn't like boost at all. It appears there is a restriction at around 340 or 350 hp. After that it doesn't make good hp. 20 psi is hardly any more powerful than 16 or 17 psi which indicates a flow restriction or bad intercooler that has pressure restriction. It went about 350 at 18 psi but went almost the same hp at 16 psi. Needs pipework fixed up. Blew 2 pipes off. Base timing was 10 degrees out. Very hard work."
So it's not perfect. But it's my car, so it was never going to run smoothly. I am just happy it made it off the dyno in one piece and didn't commit suicide again :glare: anyway, for now I'm happy. I now intend to hammer the thing at Powercruise, drive it and enjoy it for a bit, and then see what needs doing.
Just gonna copy/paste from the Hypergear thread, cos I'm lazy :P
So here's my graph:
Red line is high boost setting at 18psi, blue line is low boost setting at 16psi with the gain set more conservatively to bring it on slower. You can see there isn't a lot of difference in the power output between the two settings. Compared to the previous tune at Allstar, I have picked up almost 1500rpm of response though. Full boost used to be at almost 5500rpm; now it's at about 4100rpm. So it's a totally different beast. This is even more responsive than my old G2 used to be, so the new setup is doing something right.
Still can't drive it myself though, stupid pain medication :(
And here is the video I posted in there as well:
Edited by Hanaldo
Glad to hear its back on the road and running!
Sounds like there could be some more left in it with some further tweaks, but probably best to just enjoy it for a while for now :thumbsup:
How did you find Garage 101 overall? Hopefully not too much longer until I can speak to them about tuning my car.
Highly recommend them dude. Danny was great, very very helpful. He didn't come across as just being interested in making more money, he seemed like he genuinely WANTS to tune my car. Walked me through everything he did, couldn't get hold of me while I was in hospital so he texted me instead, gave me a list of things he thinks might be causing the restriction and where to start, etc. Whole thing only cost me $715 as well, $550 for the tune (complete retune, he didn't use any of Allstar's settings) and he needed to weld some pipes for me, etc.
Awesome, can't wait to get mine done :)
Bit of the first cruise session from Powercruise yesterday:
Mate who filmed this has a video on his phone of the second cruise session with SimonR32 walking all over me :P will get it from him.
Edited by Hanaldo
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
