Hi fellas,
I'm after the front bumper mesh/grille piece that goes where the front bar covering the intercooler area is. I want this exact type - not too thick and not too thin looking. Where to buy?
Cheers
SM
https://www.sau.com.au/forums/topic/394679-r33-gtr-front-bumber-meshgrille/
that autobarn mesh is utter crap... pls dont..
goto a security screen doors place and have a look at their stainless steel mesh, it come in different gauges so you can choose how big the holes are and their shape...
and its black, its tough and its not expensive.
I used it to cover my FMIC and its been on 3yrs and still looks perfect, even after having a small bird hit it...
HI mate, yeah I totally agree...Autobarn mesh looks terrible and it ain't going to grace my Skyline.
Can you post up some pics of your meshed intercooler area? Also, any contact details of the security door place you got it from?
Cheers
Hey mate, I just went out to have a look at mine and its heaps different. It has an extra bit at the bottom and folds etc. Don't think it would fit. Sorry dude
No worries thanks mate. I would have thought it would be a different size anyway.
Any other details of where to get this mesh?
I got a fairly fine gauge, and it was an offcut so it was cheap as....
Thanks for your troubles buddy...appreciate these pics. However, the pattern of the mesh is circular not straight zig zag which is the type I'm after.
Cheers mate.
  • 5 weeks later...
Kevin,
I have exactly what you are after, taken off my Series 3 BCNR33.
Feel free to pm me with a serious offer if you want it, bare in mind they are impossible to find and very expensive from Nissan if you need to replace, so I won't accept peanuts for it
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
