UPDATED LIST OF PARTS AVAILABLE
Still got these parts to clear!!!
Can get pictures of everything on request.
rb25det s1 motor, complete minus turbo/manifold etc, compression 145-160 on all 6 cylinders - $1200
(made 194.6kw with std. turbo on 12psi with full exhaust and intercooler so very healthy)
rb25det s2 gearbox 86,000kms on it - $1500 or as a manual conversion kit $1800 (everything you need)
HKS GT2835r turbo (420hp rated, seen couple track days since rebuild made 290rwkw on another car)
kit including HKS cast manifold, Greddy ext. gate, screamer pipe, dump pipe, steel braided lines,
turbo intake and hot+cold side piping in lobster back stainless steel by AM Performance - $2200
AM Performance cat back exhaust system 2x2.5" in to 2x4" pipe with titanium tips - $950
Yellow Jackets coilpacks for s1 rb25 (all working, used for 1 year, fantastic coilpack, search forums) - $250
ORC Single plate clutch, 409 series unsprung center, used for 6months still in good cond - $400
Sparco sprint + R33 drivers rail 2 months old $650
Sparco Evo 2 Plus seat, no rails, brand new $500
Wlabro 550hp intank pump - $100
R33 BC BR Coilovers, used for 4000kms, like new - $900
KTS Sway bars front and rear with bushes - $350
R200 locked diff, tight as - $200
Kazama castor arms suit r33 and other models - $150 SOLD
Rear camber arms unknown brand, brand new - $100 on hold
R32 genuine GTR intercooler - 150
q45 afm - $80 SOLD
RB20/25 Short Shifter - $50
R33 Carbon Slam Panel/radiator cooling pannel - $100 on hold
R33 Nismo strut brace with brake stopper $180
Pineapples - $40
s2 dash surround with vents, buttons and clock, mint $100
s2 door trims with switches, mint $150
Work VS-XX 3pce wheels, 18x10 +13 front with kumho ku36 tyres 60%, 18x12 -4 rears with bridgestone tyres 40%
Just dropped two off to get re-polished and some rash taken out, may even re-powder coat the centers for those interested. Will be as new $3200
Make me an offer!! Im pretty reasonable, the worst I can say is no smile.gif
PM or 0422 314 938 - Marko
Edited by SkyHi_33
Also, im going away overseas in 3 weeks so want to clear everything!!!
Have all standard parts still on the shell, door trims, interior bits/consoles, engine bay stuff like brake master, clutch master, steering rack, alternator, starter motor, power steering pump, standard suspension arms, body panels, bonnet boot doors guards lights etc.
Everything must go!!!
Will be taking pictures of everything tomorrow and posting it up in here so keep an eye out, anything youre interested in PM me, Located in SA but can post anything anywhere!!!
Edited by SkyHi_33
Bought the R33 brake setup from Marko great guy to deal with sorted everything out including shipping and sent me heaps of pictures. Would definetly recommend him as a seller =] thanks you for pleasant smooth transaction.
Item was as described and pictured and boxed properly with all the parts/bolts.
Edited by DarkRyda
still got the z32, rear camber arms, castor arm and lock bar? pm me if so
Sorry, z32 and castor arms and lock bar are all sold, camber arms on hold! Will let you know if it falls through.
Thanks Justin, was a pleasure. Loving what youre doing with the brake kit and your car :)
Edited by SkyHi_33
Hi mate, is this a series 1? if it is i'm quite keen on the bonnet provided you still have it and can ship it to wa 6155 (at my expense of course)
Just let me know
Cheers
Nev
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
