You're just after a bleed valve boost controller, yeah? I have one off my car when I was running stock turbo. Currently set to ~11psi (assuming standard 5psi actuator). Just needs screwdriver to adjust.
If Josh falls through, hit me up. You've got my number ;)
https://www.sau.com.au/forums/topic/394835-wtb-boost-t/#findComment-6277098
I have these:
Blue one is a screw valve and not as good: $15
Silver one is the high boost model (from memory up to 60 odd psi) and hass a ball valve which according to the sales pitch brings on boost earlier. Just google the website turbo tech: $30
Pick up QBN anytime and will be at the car show parliament house sunday.
James
https://www.sau.com.au/forums/topic/394835-wtb-boost-t/#findComment-6277399
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
