Time has come to move this car on. I have a GTR sitting at the oldies I want to bring home. Bought the car in start of 08 and with plans to make it a nice streeet car with a bit more power. 4 years on and the car sits in the garage and is only driven to shops and back and occasional weekend to friends place, etc. Only done 5-6000 klms since iI bought it. Have some Mods which was going to be installed when I got a turbo, etc toall go on together, just house reno's coming first.
All parts will be sold with the car or can look at removing some parts to lower the price upon negotiations
Standard Info:
1999 R34 GTT
White, Coupe
Manual
Original ODOmeter reads 58, xxx klms, Have installed Series 2 ODOmeter with Carbon Fiber surround with 74, xxx klms and have travelled around 500-600klms on it
Rego till November 2012
LOCATED in Windaroo 4207 (near Beenleigh)
Contact: 0438 88 68 93
Interior:
Nismo Key
Leatherette Seat Trims - Black & White with GT logo (see pics)
Leather Center console lid, Gear boot & handbrake boot
Series 2 ODOmeter
White Globes (Center lights & map lights)
Impul Pedals
Aftermarket Boost, Oil Temp, AFR guages - AFR sensor wire not installed to O2 sensor yet
Exterior:
Do-Luck Front bar
Bomex sides & Rear Bar
Blitz/URAS Front Qtr Panels with Vents
LED Tail Lights (Bought from Just Jap)
LED Boot Brake Light
Clear Side Indicators
Also have LED panels to make the reverse lights bright white but not installed
Wheels are Gram Light 57C's 8.5 Front / 9.5 Rear
Rear tyres have almost new Federal RSR Semi Slicks 255/40/17 with 90-95% tread on them
Engine & Brakes:
Power FC - Have original ECU to go with the car also
Yellow Jacket Coilpacks
Blitz ID3 Boost controller & Powermeter URAS Limited Edition - Not installed
3 inch Cat back with cannon
High Flow Cat - Not installed Brand New from Just Jap
3 inch Split Dump Front Pipe with flexi pipe - Brand new never installed
O2 Sensor - Brnad new sitting in the new dump/front pipe
Greddy FMIC
40mm Aluminium Radiator - Cooling system was flushed when installed and filled with Redline Coolant with 20% antifreeze
Tein Coilovers
Alarm/Immobilizer with built in Turbo Timer
DBA Slotted Front & Rear rotors - Brand new not installed
Braided Brake Lines - Brand New not installed
Braided Clutch Line - Brand new not installed
Magnetic Oil Plug from PMR33's group buy
Apexi POD with S/Steel pipe to Z32 AFM with plug - Brand new never installed
Hopefully havent forgotten anything but can check out the car yourself if interested.
Price is $16,000
Pics below
https://www.sau.com.au/forums/topic/394906-fs-r34-gtt-qld/
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
