Hi peeps,
Wondering if someone out there with 1337 photochop skills (well, better than my non-existent skills) would be kind enough to chop a set of Volk TE37s in gun-metal onto this R32 GT-R for me -- I'm afraid this is the nearest to a side on shot of a gun-metal R32 GT-R I could fine -- if you have a better one, feel free to substitute:
And now the wheel:
The colour is a little off, it looks more like this:
Thanks guys -- just trying to work out if they will look good, or clash :( One final thing, is anyone sure what the widest rims you can legally fit an R32 GT-R is in NSW without engineering, and furthermore, what the cost of engineering might be?
Lucien.
They will look totally off their noodle... Best looking combo you can have!
Ignore my 2 second photoshop job... they will looks fantastic.
p.s. You do realise the R32 non-projector headlights are much cooler than the projector ones.
One clown referred to them as N1 headlights!???? He could have been right.
Anyway, they are different, so keep them!
Engineering is about $400.
click here for wheel modification legalities.
Thanks, although I think that has made me more confused. As I understand it, the widest and largest wheels fitted to the R32 GT-R were the BBS's that came on the V-spec 1 and 2, and they were 17x8s.
Now according to this doc, vehicles with an unsprung weight of 1201kg and over -- which I assume the R32 is -- are allowed to go up to 2" over the largest wheel that was offered on the car: in other words, up to x10s.
But, and this is what I don't get, your only allowed a 25mm increase in track-width.. Now track width seems to be measured from the centre of the rim on the left, to the centre of the rim on the right. So you halve the increase in rim width, then times by two, correct? In otherwords
17x9s = 1" increase in track
17x9.5s = 1.5" increase in track
17x10s = 2" increase in track
With 25mm (1") being the widest increase in track, the widest one could legally go on an R32 GT-R would thus be x9".
Is that right or am I just completely wrong?
Gojira: Thanks, I reakon TE37s are awesome, but I am trying to work out if the gunmetal grey TE37s would work with a gunmental R32.... Your photochop makes them look almost bronze/gold :P
Edit: My car has the projector style lights, which I prefer. I will be modifying them anyway for bi-xenon so I need the projector style :)
Lucien.
Sounds right, but I think its wrong. :P :confused:
Doesn't matter how wide the rim is (ie 17x8 or 17x10) so long as the offset is ok....
Fig 1. 17x8 inch rim
|_|-----|_| -> say thats a 2000mm track.
Fig 2. 17x10 inch rim
|__|---|__| -> that may now be a 1900mm track because the wheel sits further insde the guards than the 17x9's.
Fig 3. 17x10 inch rim with wrong offset
|__|-----|__| -> now you have a track of 2200mm because the offset forces the wheel to be further out of the centre of the car.
Does this make sense?
Christian
Arr, ok, so the offset helps to compensate? I didn't know that -- I thought it was basically there to ensure the wheel would clear the calipers.
So as long as I get the right offset, I should be ok even if I went to the max of 2"s? Can anyone confirm this from experience?
Thanks again guys -- appreciate the info.
Lucien.
Well, having never had any issues with the cops, I can't give any info on legal experiences, but i did have WORK 18x10's on my GTR for a while and the wheel track was less than standard because they sat further in the guards (we measured the track at UAS).
Christian
Anyone have a picture or know if a pair of buddy club p1 racing rims in the gold colour would look good on an white r33 gtst...series2?
i realli want to see wat it lookz like!
There are quite a few example pics on Buddy Club's website -- admittedly non of a
white R33, but a lot of white cars, and a black R33 with gold:
http://www.first-inc.co.jp/buddyclub/p1r/p1r.html
LW.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
