Hi peeps,
Wondering if someone out there with 1337 photochop skills (well, better than my non-existent skills) would be kind enough to chop a set of Volk TE37s in gun-metal onto this R32 GT-R for me -- I'm afraid this is the nearest to a side on shot of a gun-metal R32 GT-R I could fine -- if you have a better one, feel free to substitute:
And now the wheel:
The colour is a little off, it looks more like this:
Thanks guys -- just trying to work out if they will look good, or clash :( One final thing, is anyone sure what the widest rims you can legally fit an R32 GT-R is in NSW without engineering, and furthermore, what the cost of engineering might be?
Lucien.
They will look totally off their noodle... Best looking combo you can have!
Ignore my 2 second photoshop job... they will looks fantastic.
p.s. You do realise the R32 non-projector headlights are much cooler than the projector ones.
One clown referred to them as N1 headlights!???? He could have been right.
Anyway, they are different, so keep them!
Engineering is about $400.
click here for wheel modification legalities.
Thanks, although I think that has made me more confused. As I understand it, the widest and largest wheels fitted to the R32 GT-R were the BBS's that came on the V-spec 1 and 2, and they were 17x8s.
Now according to this doc, vehicles with an unsprung weight of 1201kg and over -- which I assume the R32 is -- are allowed to go up to 2" over the largest wheel that was offered on the car: in other words, up to x10s.
But, and this is what I don't get, your only allowed a 25mm increase in track-width.. Now track width seems to be measured from the centre of the rim on the left, to the centre of the rim on the right. So you halve the increase in rim width, then times by two, correct? In otherwords
17x9s = 1" increase in track
17x9.5s = 1.5" increase in track
17x10s = 2" increase in track
With 25mm (1") being the widest increase in track, the widest one could legally go on an R32 GT-R would thus be x9".
Is that right or am I just completely wrong?
Gojira: Thanks, I reakon TE37s are awesome, but I am trying to work out if the gunmetal grey TE37s would work with a gunmental R32.... Your photochop makes them look almost bronze/gold :P
Edit: My car has the projector style lights, which I prefer. I will be modifying them anyway for bi-xenon so I need the projector style :)
Lucien.
Sounds right, but I think its wrong. :P :confused:
Doesn't matter how wide the rim is (ie 17x8 or 17x10) so long as the offset is ok....
Fig 1. 17x8 inch rim
|_|-----|_| -> say thats a 2000mm track.
Fig 2. 17x10 inch rim
|__|---|__| -> that may now be a 1900mm track because the wheel sits further insde the guards than the 17x9's.
Fig 3. 17x10 inch rim with wrong offset
|__|-----|__| -> now you have a track of 2200mm because the offset forces the wheel to be further out of the centre of the car.
Does this make sense?
Christian
Arr, ok, so the offset helps to compensate? I didn't know that -- I thought it was basically there to ensure the wheel would clear the calipers.
So as long as I get the right offset, I should be ok even if I went to the max of 2"s? Can anyone confirm this from experience?
Thanks again guys -- appreciate the info.
Lucien.
Well, having never had any issues with the cops, I can't give any info on legal experiences, but i did have WORK 18x10's on my GTR for a while and the wheel track was less than standard because they sat further in the guards (we measured the track at UAS).
Christian
Anyone have a picture or know if a pair of buddy club p1 racing rims in the gold colour would look good on an white r33 gtst...series2?
i realli want to see wat it lookz like!
There are quite a few example pics on Buddy Club's website -- admittedly non of a
white R33, but a lot of white cars, and a black R33 with gold:
http://www.first-inc.co.jp/buddyclub/p1r/p1r.html
LW.
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
