S A U N S W - Texi, "the Original" @ Sutton Road
-2 is balmy.
some ppl got air, but you have to really push it. most of the time its just the suspension droop, and most of the time your survival instincts kick in and make you slow down for it...
how powerful is your car? you probably won’t get to 4th.
  • Replies 219
They used to do (still might, not sure) a quarterly event there on the skidpan, as far as I'm aware it was never the track though.
yep as I posted earlier (I think) they are running a Motorkhana on the vehicle manouvering (sp?) area on the Sunday. Pretty sure there wont be any more spots for that, they had 10 left a week ago. I'll be doing both :)
Oh and picked these up today, will be giving them a run on Saturday :D
A few questions after watching that video linked from page 1 for the 200th time:
  • does that bloke get air over the crest at one point in the first half of the course?
  • is the course going to be set up exactly like it is in the video?
I'm keen to know if we are going to see enough straight road to get into 4th gear at serious speeds.
Forecast for Saturday is looking good! -2 over night...shiver me timbers!
No air but car gets light depending on your approach speed. It's up to you how fast or slow you approach it.
No cones will not be exactly the same places as that video
4th won't happen on the straight unless you have mega power
i have mega power so hoping to hit 4th everytime round.
also going home hat in hand if i dont get air!
matt, there is a cruise thread for the drive down, i wont be able to head off till 4 from balmain thanks to gf's lame work.
Lol, well, here's one person going for times haha :D
Great stuff mate!!
Scott, don't worry so much! You'll live longer :D
There is a slow lap at the start where everyone goes in single file at a slow pace so you will be familiar with the track.
By mega power, I'm talking 420rwkw and upwards. I'd expect you to be in 2nd or 3rd for the whole run (of course with the exception of 1st at 7500rpm for the launch at the start)
Also that crest is like any crest you see in hilly parts of Sydney, for example the big one in Greenwich. You're not encouraged to go flat out over it and by doing so your time will be slower anyway so stuff that. If it's really bothering you I'll take you to it in the morning before runs start and drive over it myself with you in the car to demonstrate it's perfectly harmless when common sense is used :)
Hey,
I'm keen, can't believe i only just found out about this.
Are there any spaces left?
and is there any extra cost to get the appropriate cams license on the day?
Hey,
Yes spaces left. Send the form and money today and you'll be fine.
There is no extra cost for the CAMS license other than the actual cost of the license (eg it costs you no more to do it on the day, but the license cost still has to be paid)
Hey guys,
Any chance of entering on the day? Only just remembered about it now. I've already got CAMS etc
Thanks
We prefer to not do entries on the day as it's pretty crazy for the volunteers in the mornings, and we are short a few volunteers for this, but if that's the only way you can do it.....
I'll help where possible, just pint and tell me, do such and such over there....
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
