More than willing to seperate the springs and shocks. I'm really surprised nobody just bought the whole package considering how much money people on here throw away on cars for such a little gain on the track. My package was awesome value for money.
I paid a lot for these because they had already been revalved a few times to get them correct for a 32 GTR. Pm'in you now Steve
Edited by Rowdyr32
  • Replies 95
  • 3 weeks later...
  • 1 month later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
