Is this going to happen in Mexico, or up here?
Going to have to have some good fab for the exhaust manifolds to clear steering racks and things. Looking fwd to skid vids.
Dale the wise resourceful human that he is sent me a link to a place in Sydney that can do most of the work. Because they specialise in engine swap with this particular motor. Sydney is closer to Newcastle than Mexico.
Yeah also starter motor will have to be relocated as well as it will be in the way.
Ah screw it...... I'm putting a LS1 with a T56 box, single piece tailshaft and other stuff too.
So people I am looking for a whole car preferably. 2002 - 2005 VX/VY and some VZ commodore SS/SV8 Ute or sedan with under or around 130000km and MANUAL
Will pay anything up to about 7.5/8k minor damage ok. Just as long as it's drivable.
  • Like 1
You just need to wait for a wet day; you'll have hundreds to choose form. ;)
As for the starter; isn't the US market stuff on the other side? Or is it ours?
  • Like 2
Get an LS1 they said, it will be cheap they said......
Not!
My best option is a crate LS1 short block and recondition a T56 box. Whole cars are at least 8k.
Write off's are still expensive. At least with a crate I'll know it hasn't been thrashed within an inch of its life and all shiny and stuff.
Bring on all the haters <3 <3
Edited by Howaitonaito
I thought I had heard somewhere that the T56 in the Commodes was in high demand due to ham fisted owners screwing up the the transmissions and that had destroyed the market in used cheap T56 tranmissions that everyone had expected...
Going for the auto would probably save you a good amount of money, as well as being simpler to source...
Going auto also probably won't fit aswell. Would cost more for the wiring aswell and would weigh more.
My theory is that if I go manual (light) with the LS1 (heavy) it will sort of balance out the VQ (light) with the auto (heavy)
I can find T56 boxes fine. It's the motor. People are asking too stupid prices. 5.5k for a motor with 100000km+ and have to pay more to have it refurb and reconditioned Or buy a crate short motor 5 that is brand spanking new
  • Like 1
Okay, that seems rational, but also never heard the T56 describled as light... :whistling:
So you have heads arranged to go with the short motor?
V8 Skyline or Stagea, let alone the Stagline, seems like a great way to get around the direct injection engine limitations.. Hope this all works out. It will be brilliant!!
Compared to my 4at it is light Hahahah.
I haven't arranged anything still knee deep in research and weighing up costs and such.
Yeah I'm pretty keen on the idea looking at dailys at the moment so I can take the skyline off the road. Ralliart Colt or another V35
Just a buy at 13B turbo and chuck it in, simple and effective and will out perform any LS1 for the same price :P
Until it needs to be rebuilt.... Yeah theo
I would also love low end torque aswell.
So I can't get 5.7 crate motors anymore. Spoke to an engineer and because of the weight of the cat a 6lt is good to go.
Also doing supporting mods aswell. So right now I'm sourcing every bush whiteline make for the V35 and having them replaced.
Also a new engine cross member and brembo brakes.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
