  • Replies 76
PM'd. Keen for the Mine's if its quiet.
Yes, it's quite medium in true RB sound and volume but 12 minutes before you Choyda, it's been reserved by "D"
If "D" doesn't pick it up by Sunday noon it can be yours!
So Item #1 is off the market.
I assume stainless steel inside not ceramic?
Hi Chris,
According to the Nengun Website, this HKS is a Metal Cat rated as 150 cell.
Negun also sells this cat for $815.
Kind regards, Tez
Hey terry what did you replace the hks cat with? Was it a restriction? Cheers
...with a "100" KING, but nowhere near as nice looking or new as the HKS!
I do regret a little bit not trying the HKS. It came with the titanium exhaust that I bought off GTR32G.
I still have a nice set of Mine's dumps + Y remaining on the car :)
Always wonder when people are selling high end parts what that have upgraded too. Good to hear you still have some top notch stuff.
Cheers
Cheers
Your ability to use inquisitiveness and then ask questions enables you KING to think laterally as well as vertically.
You're to be commended on this :)
I'll grab that Hooker Muffler Tez :)
Send me your details
Cheers
Hooker Muffler packed n posted today A.
Payment anticipated.
Item #2 = Hooker 3.5" Straight Thru now SOLD
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
