Definately late nights, lucky my workshop has a room upstairs with a few lounges i can sleep on ;) The engine wont be here till about a month as a mate is doing an Rb26 conversion on his 32 GTSt and is selling me dirt cheap the complete motor, harness, gearbox everything i need. And i know the motor is still good and running. Tomorrow HICAS is out and RECARO test fit :) Plus clean engine bay.
Lucky bastard! I don't mean just for the room to sleep in, but for the damn workshop lol
Plenty of time to do the little fiddly annoying things that need to get done, do them now or they will always be a "next weekend" typa thing lol
Yah as you can see i have been delaying pulling the hicas out cause im removing the complete system so a little time is needed. Also been planing out the wiring for Fuel pump and the ignition switch system. (ie. control pannel with 3 switches, push button start and iso switch).
And yah BSA I never saw it in the shop but sitting at his parents house in the elements under the tree made it look im guessing alot worse. Wish i had a photo cause it would be an amazing transformation. Im still getting spider webs around the place and a few ants so might have to get some spray out lol.
:domokun:
Well 3/4 of HICAS is out here are some pics.
HICAS In
HICAS Out, Lock bar in
Middle lines removed, Next engine bay.
So through the week Rest of HICAS lines will be out Power steering pump modified and some wires run for fuel pump and possible battery relocation. Then a rest for Easter :) hopefully my brakes might turn up and my other surprise :)
Ok so done a bit of work since last post. The rest of the HICAS has now been removed (fair bit of weight). Power steering pump removed to be modified. (will add picks soon) Engine bay is ready for pressure clean in preperation for a new coat of matte black. And while all this was going on this arrived in the mail! :thumbsup::nyaanyaa::worship: Easter weekend im going to have a nice rest and refuse to touch a car in service terms. But when I return to work RECARO's will be test fitted and hope to start on battery relocation and fuel pump wiring. Happy easter all and will Update again soon.
Cheers bud looks like its clear coated already, for the time being it will just be sitting in my shop inside in the shade so should be sweet. But will double check before fitting to car. :)
I doubt it has been clear coated, most cf fabricators don't do that. You're most likely just looking at the wet finish of the resin.
Well hope easter was good for everyone. So on friday my front calipers arrived. In good condition but unfortunately they have no slides so ill have to find some otherwise the pads wont stay in. I got them cleaned up and sprayed them orange. Originally was gonna be dark purple but couldnt find caliper paint in that colour. Must admit the bright orange shall stand out against the matte black. Also picked up the rear calipers today. Very complete, even came with pretty much new pads. Just need to get the mounting bolts for them. So next to come on the list is get some rotors and then complete the front set up bleed and brakes will be done. Also got myself some 5 core trailer wire so i can wire up the rear end (ie brakes blinkers ect). So now she will stop, now just to make her GO!
Fresh out the box
Freshly painted
Looking like a good thread to follow. Orange calipers definitely going to stand out on the track (but isnt red faster? haha)
I must agree red is faster but everyone has red brakes these days, i want to be diffferent lol.
Hey guys another quick update. Got the rear calipers on saturday, washed and degreased em, then got the same coat of orange paint as the front have. Also sanded back the paint off the raised nissan areas. Also did this on the fronts, look heaps better. Ordered some clips and slide pins for the front calipers (which didnt come with them :S). A little expensive but genuine nissan ones out of melbourne. also sourced some mounting bolts for the rear calipers which wernt included but the pads are brand new :) will now save for slotted rotors and then brakes will be all done :)
Calipers painted and assebled on the bench
Hey guys got some goodies delivered up from melbourne nissan. All the slides and everything arrived today. Finnished the rear calipers off. Need to grab some pads for the front along with 4 slotted rotors. All the rear lights are now wired up with the 5 core. Once front harnes is put in can just join the other end of 5 core to the switches. Might even just go a home made switch pannel in the center with all the appropriate switches.
The Goodies :)
Hey guys and girls. Well i brought some cable today for the battery relocation. The cable for earth and possitive is 4G wire. Which will go from battery to iso switch in the center cluster then to starter ect. Being that the cars original wiring is totally non existant, i mean every harnes has previously been pulled from the car ive decided to start from pretty much scratch. After wiring the rear up the other day as mentioned, ive decided to mount the battery in behind the passenger seat on the floor, this protects it from damage in case of big accident with impact from front or rear. Also brough a pre made fuse box which will be mounted in the center for easier access if any dramas arrise. Also to come will be the relay location instead of the factory engine bay box they will be inside aswell for easy access. Heres a pic of all the gear before intall. Install picks to come shortly.
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
