The day came and went. Only drama was a blown intercooler pipe in session 3, put it back on and went like a dream. 1:18 round the south circuit.
Notes for next time;
- Semi slicks
- Coil overs (to fix tramping vibration in left rear shock area)
- Lower trailer as this one was a slight prick to get on and off.
- make sure go pro works prior to event. (it stuffed up i have no vids or picks :( )
Ha ha yah a proper tow strap would be handy, although he did manage not to break the front bar lol. I want to put a standard GTR bar on eventually anyway. Im sick f being called Mr Plow lol
I knew what it was all day, leaking injector in number 6 cylinder which is also causing a bit of fuel to get into the oil. still went ok lol once i reved the shit out of it getting all the excess fuel out lol.
  • 8 months later...
So long time no update. Got married in November 2013 so funds for race car are definately $0. Another South Circuit run at SMSP is on in a few months and she shall be attending. Car is currently for sale but no serious buyers have come forward so might as well take her out again ;). Will get around the sorting the missfire out by servicing the injectors. Then time for fun and this time making sure the GOPRO is functioning properly.
  • 1 month later...
Struggling to get a trailer organised for the next event. So possibly she will be collecting dust while the 33 makes its SMSP attempt. Will probably have to start a build thread for that soon if/when i sell the 32. As the 33 is already set up suspension wise and engine wise ready for the track.
So good news. Mates got a trailer for me. Tow car will be easy to get. Found the missfire. Number 6 injector leaking. Will pull apart shortly and get all 6 serviced. Then some fresh tires on some stock 16inch wheels. And shes ready for the track! Just under a month now getting excited.
Ok getting to the bottom of this missfire. Found all signals into ignotor module to be correct. But the pulses out of the ignitor are not. There is a pulse missing from cylinder 6 on the coil side of the ignitor. Just need to find a cheap ignitor unit and should be set :)
Also had all 6 injectors serviced off car, cleaned and flow tested :)
So got me some fancy new (second hand) rims yeaterday. What a bargain price I pretty much just stole them haha. Local tire mob i used flung me some decent second hand Bridgestone and Continental 225/45/17's to get me through the track day for now. Rims look sexy and fast IMO. My local tire shop also does the Handcook semi slicks so may look into those once my wallet recovers from other life spendages.
Trailer and tow car organised for the track day, ignitor problem solved. Now just needs an oil change and a once over, plus a wash before the big day. Only a few weeks out getting super pumped. Go pro is fully working now with bigger memory card so should have some decent vids finally.
10635781_10154562566485521_8692570846785
So forgot to mention the ECU was the drama. Replaced with another one and its runing like a dream. Purchased the oil for the service today. Also some Matte black paint for the front bar. Have sanded the bar back ready for a nice fresh coat, now the car wont look so fugly with a maroon front bar. Small exhaust leak found at flange at rear dump pipe where it joins the straight pipe. While on hoist will put a new gasket and some sealant in. Then its onto the trailer on Sunday arvo ready for the track.
So guys had a great day out at the track. A new PB for the Ninja round the south circuit. 1:15.48. which is 3 seconds quicker then last time which was a 1:18. The new tires worked great and running on 6 cylinders helps. Only ran 8psi of boost all day. Still need some work to the rear end to stop some chatter under corner exit but all in all an excellent day! heres a video and some picks :)
  • 2 months later...
So long time no update. Have decided possibly in the new year to get her registered. Ran a REVS check on the vehicle, it has had prior NSW rego. Was imported between 89 and 2001. Doesnt give me a year model though but has the original engine number.
Other good news at there is no money owing on it, no stolen record, and no written off history. So its a clean car :)
Repairs required for road use are pretty simple. Wire up and install a horn. Install front indicators and wire in the flasher unit. Thats about it.
And obviously get the money for rego and insurance. That way i can justify owning it and be able to drive it to and from local track days and test drive on the road.
  • 1 month later...
Well well well. The Ninja gets one stem closer to rego. Installed the Hazard switch. Charged the battery. flicked on the ignition and kill switch. Hit the indicator button and bam flash flash flash of the front blinkers :) Then i had the tricky task of locating the 2 in 100 wires that flash for the rear blinkers as im not running the factory rear harnes. Managed to find it quickly at the big square grey plug that the factory harnes would normally plug into. Connected and bam all 4 blinkers working.
So a small victory now just need to get a blue slip. and then register it. Park it in the workshop for a month so my blue slip bloke doesnt get in shit if i get pulled over as i can say i built the car after it had rego :P
  • Like 1
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
