Hey all,
I have a set of old work emesh wheels for the cressida that have seen better days.
I'm going to take the centres off and get them sand blasted then repaint them.
Is there a place in canberra that can sand/bead blast them for a reasonable price?
Cheers,
Andy
https://www.sau.com.au/forums/topic/396198-wheel-sandblasting/
Dont know Andy, sorry mate.
I'd like to get a set of my Wheels professionaly cleaned and coated.
So if you stumble across a shop in your travels that does this then please...get in touch.
Just thinking most smash repairers may be able to help you there.
Call Peter at Prestige and ask him.62601359 :thumbsup:
AA sandblasting fyshwick, i think its $30-$35 a rim,
cant remember the guy who paints and powdercoats, powdercoating was about $100-$110 a rim if i remember right. paint was more expensive.
or you can DIY with a wire brush and sandpaper, etch primer, wheel paint and lots of elbow grease. (thats what i did)
Wheel paint in a spraycan is not anywhere as strong/hard as powdercoat or 2pack. (wasted effort?)
You could get them blasted then get some GOOD 2pack paint from Allards or other auto paint suppliers.
So theres options. All depends on your $$$ and time.
Edited by D.I.Y. Mik
or theres is soda blasting too.
really bloody amazing stuff, will strip paint off a 1970's car door without harming the chrome plastic trim.
+ it doesn’t pit the metal like sand blasting, meaning surfaces are ready to coat straight away...
sodablastact in hume.
+ it doesn't pit the metal like sand blasting, meaning surfaces are ready to coat straight away...
Is Awesome :thumbsup: but dont try it on an aluminium bonnet :down:
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
